  • Replies 6k
Posted Images
we should have a SAU poker night..only say $10 - $15 (more if you think its not worth it) buy in to make it worthwhile and have fun - which is the whole purpose, of course. Or is everyone too busy pr doesnt know how to play??
well i can understand staying away from casino as when i finish working there i dont want to be anywhere near it, ill be in for poker. Dont worry i dont deal it.
