  • Replies 6k
Posted Images
i havnt seen that one.. I will post up links to more fat vids that i find online of bike stuff... Ive found a good one of a zx10r Ripping it up on a windy road!!!! This might be more your style brendan!!!!
Its a nice ninha by the looks: :woot:
http://www.uponone.com/videos.php?id=4779
Thats the riding I do...... maybe add a few more mph tho!! LOL
Had a pretty close call on my bike today (on private property) doing about 120 -140 (ie max speed on klr 600), throttle just went dead and motor felt weird and then conked out so i let off throttle and down shifted to roll start it (must of gone down two gears or something) the rear wheel went into a compression lock for about two seconds and back came out a bit..... Damn close call...after that bike was running fine --0 it was really weird as i have never had anything like this happen b4? maybe it was just a bubble in the fuel lines or something?
Any of you bike riders had this happen to you before?
I think next time i will just hold the clutch and pull over (bit safer mez thinks!!)
happened on my zx7R, iced carbs.............. common problem with the late 90's ZXR's.
Winters weekend day, cool air, long ride, loss of engine power, down a few cogs to slow it down, lock rear wheel (where was the slipper clutch in the 90's LOL), big slide, no power, BAM on it comes with compression, black snakey all down the road (oh and black undies too). Pull to side of road and let the carbs warm up again.
Brendan this is perhaps the best street cycling vid i have ever seen: its a cut down segment of pascal on le Perlipherique ie its the highlights from a lap around paris in 12 minutes: this guy can REALLLLLYY ride!!!!!!!!!!! He defenitely has a death wish!!!!!!!
http://www.uponone.com/videos.php?id=124
WOOHOOO Got the 6.1 Hemi 300C :D in today. there are only subtle changes from the standard 5.7 (like the extra 68kw) the main thing are the 20 inch wheel with monsterous brembo brakes. I would easily get one of these beasts over a FPV or HSV. Got to say this is one of the only good things about my job :P
Can't wait to get the jeep equivelant 0-100 in 5 seconds - take that Holden a 2 tonne 4wd is faster than the GTS
Winters weekend day, cool air, long ride, loss of engine power, down a few cogs to slow it down, lock rear wheel (where was the slipper clutch in the 90's LOL), big slide, no power, BAM on it comes with compression, black snakey all down the road (oh and black undies too). Pull to side of road and let the carbs warm up again. {and change undies!} :)
i just wanted to say i walked into work this morning only to feel my right foot was soaked on the front part. it seems i have a hole in the bottom of my shoe...
on another note, i cant change my avatar pic...it keeps going bk 2 an old one that i had and it would go away...i cant change it...any have any ideas?
    • Definitely a good “future upgrade” option if you plan on keeping the car and dialing it in even further.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
