  • Replies 6k
Posted Images
WOW whiplash that was amazing
pixel8r i do find parking not allways easy in my line 9 times out of 10 i take 2 stabs @ getting in parks and u-turn i cant make using 3 lanes it takes a good 3.5 lanes where normal line will do it in like 2 lanes to 2.5
We had a new Silver GT stolen from work friday night!!!!!!
the keys got stolen on friday and they came back for the rest of the car during the night. Two sets of Gates were cut through to get to the FPV.
not expecting to see it in 1 piece again
:P:(
yeah true but who reviews a car like the gtr and complains because you cant park it easily? So you may have to do a 3 point turn instead of a u-turn - they made such a big deal over it...
I'm not always good at parking in my stagea and sometimes I take more than 2 goes (lol) but its the kind of thing you get used to and you just park, get out the car and not think twice about the fact you took 2/3 goes to park it right...
Anyway, there are a lot of things about that review that made me think it was biased. Obviously no mention of the gtr gearboxes since that would spoil the wrx comparo lol :laugh:
anyways....moving along... :P
I just had to say, last night I had to really USE the brakes in my 33 GTST for the first time, and the stopping power was incredible! Standard brakes and normal discs, 18" rims on 235's all round, coilovers.
My old car had ABS and so I was never sure what to expect from these when I really locked them up. Slowed me right down until it locked up, and even then it stopped in its tracks. Very impressed, and I'm very happy that myself and my passengers are quite safe in this vehicle.
Me little piece of crap Corolla got defected on Friday night............ They defected it for having the track out of the guard on the drivers front wheel, and on the paperwork they put down it was a MAJOR defect, so i questioned him on how it could be a major defect and why he is sending me to Regency and why i couldn't just go to Sturt Cop Shop, and unfortunatly he showed me the book and wasn't much i could do.......
In saying all of this the cop actually rang me back the next day(must have been thinking about it/me) and said that i could take it to Sturt Cop Shop, I was cheering, couldn't believe my luck!
What a load of crap in that Autospeed review of the GT-Rs about never being able to relax while driving, put your arm on the window etc. Mine drives just as smooth as any other car I have been in.
Perhaps it's because they were reviewing a V Spec, and mentioned something about it having negative front camber :S
so non ABS brakes are better than ABS, can u tweak ABS to no go into ABS mode at the first sign of 1 wheel slightly locking due to loose or bumpy surface where all other wheels are not in danger of loosing traction
EDIT
just went to boostworx from slimjims sig
needs updateing
SAU dyno day
Edited by Madaz
Sounds right for a 100% stock GTR. :laugh:
Thats around 220-230fwkw.
(just realised fwkw here means 'flywheel kw')
270Nm wouldn't be right either would it - not sure how torque goes at the wheels in a manual. In an auto torque is multiplied at the wheels due to the torque converter so you get very high torque figures in autos generally. Not sure if the same is true for a manual tho - but 270Nm is definitely low...
173kw at all 4 would be about right for a stock GTR. Doesn't sound much but remember max power is only part of the equation. Its all about how quickly you get to that figure, which is where torque comes into play. Pretty sure GTR's have 400+ N-m at the engine - and every bit of extra boost will see this figure climb upwards...boost=torque.
Torque measured on a chassis dyno is dependant on things like gear selection, dyno roller radius, wheel and tyre size, torque multiplication via converter if auto, etc etc etc - about the only thing you can compare is two identical cars on the same dyno in the same gear with the same wheels and tyres at the same stage of wear.
Engine torque is a meaningful comparison, but difficult to measure or estimate from chassis dyno figures.
Thanks for that - I knew there was a reason you couldn't compare torque at the wheels from dyno readouts - but never knew why...
cheers. :laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
