Did they say why they couldn't remove the rear left wheel?
Lock nut? Spinning stud?
Either way you should be able to spin the wheel around and see with a torch how much meat is left on the pad. Looking at the opposite wheel will give you a good indication how much meat is left on the left.
The skylines brakes wear fairly evenly due to being 4pots up the fronts and 2 pots at the rear. So the inner doesn't wear early like that of the usual clamp type pos brakes.
I wouldn't be concerned.
Have you bought it yet?
Get under the car and check the chassis rails for damage.
  • Replies 6k
Posted Images
yup :wave:
hey guys i need a little advice, im purchasing the car on friday but there is a small problem and that is the RAA couldnt get the rear left wheel off the car to check the brakes on that rotor.
Got any advice, should this sort of thing hold me up greatly?
why dont you take it to a workshop that specialises in skylines? RAA is pointless when it comes to these checks, they only good for when your car breaks down and needs a tow.
yup :wave:
wtf? Id be wondering why they would not be able to take a wheel off...cbf, or something wrong?
I'm not too fond of the RAA inspections.
I bought a VS 5ltr 5speed some 7years ago, had it RAA inspected and they missed an obvious inlet manifold water leak and loose engine mount that had the exhaust hitting the body under acceleration. :wave:
The inlet manifold leak was a real pain in the arse to get fixed too.. They had the car for 3 weeks and racked up almost 70km's, I got it back and the clutch felt all spongy like they had been slipping it. :)
From there that car was down hill... Such a damn unreliable (drivetrain) money pit. Well at least the new owner got a good deal; new diff, gearbox and rear subframe. :O
The RAA said that "several of the wheel nuts were damaged, so unable to complete brake check."
The guy did a very thorough report and they do check everything on their check list. I mean id want a full refund of the 200 dollars i spent to get myself some peace of mind before buyin the car.
I'm not worried about the brake pad, Im worried about the wheel coming off, I think im going to tell him that I'm not coming to pick up the car until he can get that wheel off and then refit it with new nuts. without breaking his nuts is the key, but i guess im the one with the cash anyway.
Edited by SAZilla
so he has to brake a nut to get the broken nuts off :dry: how do nuts get broken...id ask for explanation.
he is thorough, but did they do a compression check?
yes, came up with 5 percent within eachother,
is that good?
@cubes, private sale bud
my mate said if the problem is that serious ill have to spend quite a bit to get the thread welded back onto the rotor or whatever to repair the damage done by the nuts. only problem me and my mate -who knows quite a bit about turbo vehicles- picked up was just a scratch on the door that could be buffed out and thats it. the car was beautiful on the test drive.
Edited by SAZilla
Update: I rang mike said to him id pick up the car on monday definitely if that wheel was removed then refitted succesfully, he agreed and is getting a mechanic to do it. so thats sorted...
so yer 5 percent is what the RAA said, I gather thats 5 percent loss or 5 percent difference between all cylinders.
5% variation is a fair amount but I'd say its most likely <5% which is considered ok.
The chances of a car thats 10yrs old having near perfect compression ratio is slim.
Please cheak the head lights when you pick it up... I was excited and forgot to... Turned the head lights on and then had to hunt around for H3C bulbs that absolutely no one had apart from autobarn that was closed. :dry:
yep the lights in her have been changed already, all but this rear wheel bullshit is fine. all the suspension and undercarriage is fine aswell but he couldnt check out that disk and that wheel and anything behind it. i rang the guy and told him to fix it for me today so i can pick up car on monday. so hopefully all goes well
easy
when i go to pick up the car, with my mate, I will say:
"fixed that wheel?, I want to just check the brake pads and the rotor before I give you the cash."
then ill check it, find that its all good, and then bang im done.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
