  • Replies 6k
Posted Images
Pokie.. Have you got pics of that birthday cake you've been talking about?
It is a proper b'day cake isn't it? Not some el crapo cheese cake shop thing? :whistling:
nah no pics, was thinking about taking some but i didn't :thumbsup:
it looked so nice, so chocolatey mmmmmmm
hehe was Mocca Torte from the Cheese Cake Shop
i told my parents that i didn't want them to sing "happy b'day"
to me. was in the middle of watching the OC my dad comes in
and says "oh that guy with the WRX is here at the front door"
butt-head fooled me :cheers:
^^^^ Gold......... I'M RICH BIATCH :)
Oh the weather, yeh alot cooler than yesterday! :yes:
LOL :yes:
Is it awesome :) Is the whole city going to be closed Friday cause of tour down under??? or only part of it I want to go out to dinner friday night to Gouger st?? :huh:
