  • Replies 6k
Posted Images
seems we had a gig up in the party pit at work last night for clipsal.
so im thinking jarad may've been there?
sounded like it was pretty fun, its always great dealing funny money games, you get to f**k around and be a complete idiot all whilst being paid for it.
so pissed i wasnt rostered to work it, i loved the last function :D
seems i may finally be moving out of this hell hole of a house soon aswell, awesome!
means my skyline purchase might be put off for another year or so though, *sigh*
Ohhhh noooo scandyflick!!
What happened to the soara?
Morn' all i so love not being @ work :D
was just looking around for some ideas for other peoples sigs and came across this might be a spoiler but anyway, just a message of think before we type makes a world of difference
1. Keyboard Warrior
...4. Keyboard Warriors are generally identified by unnecessary rage in their written communications, and are regarded as 'losers' by other virtual identities on the internet.
Has anyone changed the clutch on their 33 (or 32 with 25 box) and can provide some guidance? My clutch is showing signs of saying farewell, and I would like to give it a go myself but have never changed a clutch. Is there special tools needed (aligning tool?) and would it be possible to do it without a hoist? Also, removing the flywheel for machining, how hard is this? and how long would my car be out of action?
I tried to search the DIY section, found some help, but would like to know if anyone local would mind lending some advice and some help possibly :D
Cheers
<a href="http://www.urbandictionary.com/define.php?term=keyboard+warrior" target="_blank">1. Keyboard Warrior
...4. Keyboard Warriors are generally identified by unnecessary rage in their written communications, and are regarded as 'losers' by other virtual identities on the internet.</a>
Maz, :0
I am not a keyboard warrior, I am actually the total opposite and proud of it!!
I tried to search the DIY section, found some help, but would like to know if anyone local would mind lending some advice and some help possibly :nyaanyaa:
Cheers
You'll need a couple of long extension bars for those top gearbox bolts, clutch aligning tool, 2 hydraulic jacks, some rope, spanners, sockets, needle nose plyers or sirclip removers and a mate to give you a hand.
I drain the gearbox oil, remove the tail shaft from the rear of the gearbox, disconnect speedo drive all plugs remove the shifter (via inside the car), starter motor etc
Shove one jack under the rear of the gearbox and tie it up so it won't slip off while rotating the gearbox. One jack up front to help take some weight.
Drop the rear of the gearbox slightly so you can get at the top bell housing bolts easier, remove all bolts then get either side, slide the box out a little, rotate clockwise so the starter lump clears the floor pan and then slide it out while slowly lowering the jacks. ;)
Leave the box under the car and as it is. Remove old clutch and flywheel, have the flywheel faced if you wish and replace spiggot bush (pack the crank end full of grease and use a suitably sized socket and small extension bar + hammer to get the old out)
Smack in the new spiggot, attach flyweel remembering to locktight the bolts.
Loosly bolt up the new clutch, slide the clutch aligning tool in, tighten up the pressure place bolts then slide the gearbox in doing the opposite of what you did to remove it.
Refill with oil. I think thats it. :nyaanyaa:
EDIT: And always plan an escape route incase you drop the box. :D
Cheers for that cubes!
Do you do this in your shed with the car on Jack stands, or is a hoist really more necessary?
Also, where can you get a flywheel machined southern suburbs, and any idea of cost?
Cheers!
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
