There's a LOT of variables.
Placement of inlet air temp sensor, how the car is strapped down, tyre pressure, shootout mode run etc etc.
Its fairly easy to see a variance of 5 even 10rwkw depending on the above.
I believe it actually reads pretty much spot on if not a touch low. R33's with PowerFC's generally see 190-200rwkw; with cam gears or a 13+psi 210rwkw is achievable.
Mine was maxing out the afm and injectors at around 180rwkw; another mates also max'd his out at the same power.
BUT just because the afm is max'd out it doesn't mean you can't go on to make 220rwkw with the stock afm. Its just that the tune is a tad crude but it works.
Agreed, and i know/understand that. Its just i have seen a few cars get roughly 20kw less at some other places.
Edited by KISIN
  • Replies 6k
Posted Images
What dyno Kisin?
Graham Wests dyno reads 'slightly' lower than Shauns and thats a mainline which is known for reading lower than DD Dyno's.
So I'd say the dyno thats reading 20rwkw less which is a hell of a lot has something funky going on with inlet air temp sensor placement, shoot out mode or lack there of or strapping it down too hard.
Strapping it down TOO hard WILL definitely give a lower reading. 20-30rwkw is not uncommon.
Maybe the person strapping the car down hasn't got all that much experience with the dyno?
Which is why Dyno's are only good as a tuning tool; too many variables.
With regards to shootout modes. 'Generally' the lower the shootout mode the lower the same car will read; shoot 6 vs shoot 8 for example. Shoot8 will read slightly higher. This was shown at a boostworx dyno day when Chop's LS1 was run up in Shoot6 mode and made 20-30rwkw less than in shoot8F.
For what ever reason I've noticed Shaun usually runs in Shoot6 mode (should be shoot6f). Possibly more so for tuning reasons as the higher the shoot the less aggressive the ramp. Thats the way I understand it anyway. :ninja:
Kissin,
Same dyno, same customer, same shootout mode, very similiar amb and it temps.
Only variable (that i'm aware of); different strapper downerer and 24rwkw :ninja:
As you can see; only good for a tuning tool; dyno days are a fairly good indicator as they have a common variable; same day, same operator and strapper etc.. I'm not a believer of placing the IT temp sensor on the pod or airbox as it doesn't reflect 'real world' performance.
On the road; the car with the pod sucking that hot air doesn't have its power magically increased because its sucking hot air; power will be down.
So what I'm getting at is two cars side by side same gear same speed; one with a sealed airbox and cai; another with a POD. On the dyno they make identical power. Who's going to out accelerate who? My bets are on the car with the sealed airbox even though it made the same power as the car with the pod due to the dyno's power correction based on IT temps.
Hope that makes sense.
Look the way i see it, Use the same dyno everytime, As long as it's tuned on the same dyno it's all good! And when a a Dyno day......... don't take it too serious, Doesn't make your balls any bigger just cos you have more power!
.....yeh it does :)
haha, nah i know what u saying.
Haha yes is does daz, just cause you dont have much lol....
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
