  • Replies 6k
Posted Images
i havnt seen that one.. I will post up links to more fat vids that i find online of bike stuff... Ive found a good one of a zx10r Ripping it up on a windy road!!!! This might be more your style brendan!!!!
Its a nice ninha by the looks: :woot:
http://www.uponone.com/videos.php?id=4779
Thats the riding I do...... maybe add a few more mph tho!! LOL
Had a pretty close call on my bike today (on private property) doing about 120 -140 (ie max speed on klr 600), throttle just went dead and motor felt weird and then conked out so i let off throttle and down shifted to roll start it (must of gone down two gears or something) the rear wheel went into a compression lock for about two seconds and back came out a bit..... Damn close call...after that bike was running fine --0 it was really weird as i have never had anything like this happen b4? maybe it was just a bubble in the fuel lines or something?
Any of you bike riders had this happen to you before?
I think next time i will just hold the clutch and pull over (bit safer mez thinks!!)
happened on my zx7R, iced carbs.............. common problem with the late 90's ZXR's.
Winters weekend day, cool air, long ride, loss of engine power, down a few cogs to slow it down, lock rear wheel (where was the slipper clutch in the 90's LOL), big slide, no power, BAM on it comes with compression, black snakey all down the road (oh and black undies too). Pull to side of road and let the carbs warm up again.
Brendan this is perhaps the best street cycling vid i have ever seen: its a cut down segment of pascal on le Perlipherique ie its the highlights from a lap around paris in 12 minutes: this guy can REALLLLLYY ride!!!!!!!!!!! He defenitely has a death wish!!!!!!!
http://www.uponone.com/videos.php?id=124
WOOHOOO Got the 6.1 Hemi 300C :D in today. there are only subtle changes from the standard 5.7 (like the extra 68kw) the main thing are the 20 inch wheel with monsterous brembo brakes. I would easily get one of these beasts over a FPV or HSV. Got to say this is one of the only good things about my job :P
Can't wait to get the jeep equivelant 0-100 in 5 seconds - take that Holden a 2 tonne 4wd is faster than the GTS
Winters weekend day, cool air, long ride, loss of engine power, down a few cogs to slow it down, lock rear wheel (where was the slipper clutch in the 90's LOL), big slide, no power, BAM on it comes with compression, black snakey all down the road (oh and black undies too). Pull to side of road and let the carbs warm up again. {and change undies!} :)
i just wanted to say i walked into work this morning only to feel my right foot was soaked on the front part. it seems i have a hole in the bottom of my shoe...
on another note, i cant change my avatar pic...it keeps going bk 2 an old one that i had and it would go away...i cant change it...any have any ideas?
Guest
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
