no there is not ... you have to chase to the workshop MANUALS FOR EACH ENGINE!
GTR
vL COMMODORE
GTS/GTS-t
Ok, has anyone out there used these manuals
to rebuild an RB himself?
Want to know how they went and
how helpfull these workshop manuals are.
Cheers,
Thanks In Advance.
if you're looking for a step-by-step guide then i would suggest you keep away from your engine completely.
BUT.. the workshop manual has info with pics on how to disassemble and assemble parts, and each part is set out in the order they need to be done. i.e. engine removal, then head removal/disassembly/assebly, same with the block and other parts around the engine... as well as clearances and how to check them.
are these available online? i remember they were up a while ago.
    • Quick update, finally got an hour or two on a weekend where there wasn't shit weather, no sick kids, people visiting our house or had to work. Visited me old folks and the skyline...dropped  $10 of 98 in the tank and a brand new SCA shitter battery in. Cranked over a bunch of times but didn't fire up....pretty sure it's not getting any fuel. Gonna try some of the stuff suggested above, next time I make it over there.
    • @GTSBoyas luck would have it and it's legit the only part of this story that goes my way, I already had the liner out to retrim! So much lucky!
    • Drill out the subframe bushes, replace them, same with the diff bushes.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
