Hi Guys,
I am looking at setting up a group buy for scissor doors. Also known as Vertical Doors and Lamboghini hinges. These are universal hinges so will fit all cars. I am investigating shiping details, but I think that if I can organise 10 people, It may cost around $700 - $800 delivered to your door.
Unfortunately postage is expensive as each kit for 2 doors weighs around 20kg.
The kit comes with instructions and does not require welding. I believe this is a bolt on kit with 2 hinges and 4 200lbs gas struts. The mechanism of the hinges does not require you to change the door latch. I have seen similar hinges from US$900 to US$1400, so the pricing is good. I am trying to organise a sample.
I am looking at importing them directly from China. As soon as I get more info, I will post it up.
As I'm going away on holidays next week, I will post info from time to time. So please bare with me as I won't be on all the time. I will let this run until the end of January 2007.
Thanks for looking.
Interested:
(01) Filecon
(02) 2BNVS
(03) AnDru
(04) Wraith Skyline
(05) BrendanS
(06) Walkoau
(07) SirSkyline
(08) Manwhore
(09) Ol Mate
(10) John R33
(11) Cheez
(12) sqd32
(13)
(14)
(15)
Edited by Filecon
https://www.sau.com.au/forums/topic/148903-eoi-scissor-door-group-buy/
  • Replies 66
http://www.skylinesaustralia.com/forums/in...showtopic=81129
Please read the instructions carefully.
Include all the information required. There is some missing here.
Thanks.
VDK (Vertical Door Kit)
ALL DOORS UP! Vertical Door Kit will make your car/truck stand out in a crowd. Design allows doors to swing up to 90 degrees. Do not settle for kits with inadequate door movement! To insure maximum quality each kit is CAD/CAM designed. It is a universal kit that fits all and any model vehicle.
Key Features
90 Degrees of Door Movement
CAD/CAM Designed
Smooth Operation
Adjustable Stop Points
Custom finish (gold-tin, silver-tin, powfer coating, chrome coating)
All hardware included
Key Components
2 Hinges
4 Gas struts , up to 300lbs
Gas strut brackets and hardware
Thanks.
I would also suggest people chat to an approved engineer before undertaking such modifications to a road car as they are not factory, and quite a change to the workings
Hi Guys,
I am hoping to get a set and put them on a car by the end of January. I will take some photos of the installation and let you know how easy it is and how sturdy they are.
I am checking on how many people are interested at the moment. But I wouldn't do a GB unless they are quality products and sturdy. Therefore the GB wouldn't go ahead until I have fully checked them out.
Edited by Filecon
Hi Guys,
I have them at home do you want to see some photos about them?
pics would be great so we can see how they are to be sure, but yeh good idea checking the quality etc before it goes ahead..
for someone who asked about legallity, as far as i know an engineer wont touch them....but u might find an odd one that will
either way still keen, keep us posted.
ben...
Hi guys, yeah ill be interested if its a good quality product, but my 1 question is, is with almost all scissor kits the fenders have to be modified. Is this the case with this kit as well??
Hi Brendan,
I am not 100% sure if the fenders need to be lipped (ie, the fender bit is flared as per wheel arch. I think for memory wheel arches being lipped is about $8 and there are no marks on the paint work).
Some vehicles need to be lipped whilst some don't. I can not tell you 100% for sure. In the next 3 or 4 weeks, I will be attempting :no:;):P to put a set on an R33. I will let you know if the fenders need to be lipped. :)
BTW, BanKids it would be great if you could post some pic's of your car with the scissor hinges. Did you do the install yourself ?
I have done some research on the internet re: the installation, and it can be done with 2 people. It is almost impossible to do it yourself unless you have hoists and such......
Edited by Filecon
are you still able to open the door normally?
The door opens normal initially so that it uses the same door latch, but then opens upwards.
If you are asking if you can choose to have the door open normally or upwards, the answer is no. Once you change the hinge, it will open upwards. If you want it to open normally, you need to put the old hinge back on.
sorry i don't have any pic on my car as they are still at home. but i have a mate who did the conversion and that looks awesome, just one thing, if your car is 2 doors like supra or skyline 2dr, they doors might be too heavy to lift up with just one air bar each side, mine got 2 on each side..
bankids,
These kits come with 300lb struts (2 for each door) due to the heavy weight of the door.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
