Hi guys,
i've been told that my GTR is running retarded, my Pwr FC says my idle timing is 20degrees,
That's ADVANCED. And just because the PFC says it's 20 doesn't mean it's running at 20. It all depends on when the PFC gets the trigger to start its calculation as to the correct moment to fire the spark.
Whats is the proper IDLE timing for a r32 GTR?
SEARCH. The question gets asked every other week
Does anyone know how to adjust idle timing on a PFC?
cheers!
RTFM? You can really only set the timing with a timing light on the crank pulley
okay so the standard gtr idle timing is less than 20 degrees..Gotcha, I also take it you're saying its like my computer isnt in synch with the engine? I was told that the timing on my crank is 4 degree's retarded. I posted what my power FC outputted because i was told by the workshop who installed and dynotuned my PFC that it was properly synchronized with my engine.
I appreciate the comment and understand where you are coming from, but I have searched and have not found anything specific enough to be my answer.
now now, no need to be impolite.. if i knew that i wouldnt be asking the question. I was told by reputable tuner that the PFC should have more than enough advancement to correct timing problems similiar to mine, but i'd have to pay for another retune for him to go further than that.. a different workshop originally tuned my PFC. My CAS is currently wound up full, but my engine is not pinging at all.. and apparently i'm still running retarded on the crank. the workshop that tuned the pfc says all is good, the other workshop says its off. Before spending another 500, I thought i'd try to find out more to see if i can test it myself.
my question again is in the power FC hand controller, what values do you change to increase the 20Deg to a higher figure.
base timing should be 20degree before top dead centre (ie, 20 degrees advance). this needs to be set at the CAS. you basically use a timing light to read the timing, then rotate the CAS position until it's right. any average workshop should be able to check and set it for you.
... what values do you change to increase the 20Deg to a higher figure.
If anything, you need to be adjusting some "offset" parameter so that the PFC handset agrees with the timing light.
RTFM. Or don't PFCs come with a manual?
TFM is in japanese mate.. Found some english Apexi manuals on the web, but the information is limited to "how to plug in" the PFC. The Handcontroller manual was a bit more helpful, showing how the navigate the menu's. However the manual is catered for tuning pro's, no real explanations what each item is, just how to change it.
you're right there is an "offset" parameter, but from what i was able to piece out though it seems both trailing and leading ign would have to be adjusted. I was hoping there would be a single parameter that handles both, but doubtful now.
Thanks to everyone who replied, really appreciate the time and effort.
please close thread.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
