hey guys , after a couple of days of hard work and some colour decision , iv finally finished doing my dash .
key element was time and patience , and its a major difference. iv done other sprays on other dash console's in the past but this really takes the cake. the difference is so suprising.
on my travels i did :
3 coats of primer
3 coats of metallic charcole
and about 4 coats of clear enamel
probably thinking sounds like a lot of coats but - the finish is nice and hard , i made a sample peace along whilist spraying all the others , and once all coats were conplete , i tried scratching paint off and denting it , and it wouldnt budge . the finish remains hard.
here are some pics , if any one needs and info or help PM - id be willing to help . cheers hope you like
before
primed
new
https://www.sau.com.au/forums/topic/149340-new-dash-console-pics/
  • Replies 98
around $30 awsum, im gonna have a stab at mine today..... i have a silver series 2 and im gonna try and get a silver paint as close to the outside of the car as i can ;)
i was thinking silver myself. post some pics when ur done k? :)
also u got any more pics of the front of ur car? would lik to have a closer look at ur eye lids :)
Edited by Adz2332
nice, very subtle, I like it. I've seen lots of people pain dash trim brightly, like blue, pink, silver, green and to be honest I thought they all looked like arse. yours looks nice though. ;)
no worries wen im all done ill take pics:)
i dont have any recent pics with the eyelids on as one of the caught on my pants wen i was walking past the car and snapped, so i took em off, didnt really like them any way
never really got a good photo with the eye lids on ;)
Yer i dunno bout the eye lids lol was trying to convince myself to lik the but yer dunno. i lik wot u did wid ur bumper indicators making them white! how did u go about that?
So u have the standered front wid a lip and what side skirts and rear bumper do u have?
Cant wait to c the pics hope it all works out for u
i tried calling around to get the correct paint to match my car - but i know its cheaper doing it the way i did it. also i didnt want it to be to bright , iv seen a lot of cars with crazy dash colours - particulary white - red - blue . all bright fluro type , and they peal and shit . it truelly ruins a good car - especially a skyline . i was persistant to do an amazing job , im truelly happy with the finish , at night it remains un noticable and in the day it sparkles like crazy .
Oh good job!!!
I did the shifter, ashtray, and coin-area in a glossy black... Looks pretty sweet. (MUCH better than the rough stock finish), but I didn't use primer. The paint I bought bonded with plastics, and it came out shiny but strong. It doesn't scratch or dent either.
The only problem with that was the ashtray and shifter surround turned out two slightly different shades of black! I guess primer is really the go for getting matching colours.
So... two things you might be able to help me with:
1) Could you put up the steps and times?
e.g: first coat, wait 15 minutes, sand
second coat, wait 15...
Did you sand between primer coats?
2) How on earth do you gracefully get the pocket out of the drivers armrest? I replaced it once, and getting the broken one out was easily done by breaking it some more, and the new one slides and clips in easily... getting a good one out in one piece isn't so easy!
Oh good job!!!
thanks for appreciation ! :)
my steps were :
1/ i did 3 coats with primer . i aloud the primer to dry approx an hr between each coat . a further hr before the coloured finish
2/ the colour finish can be applied in sections of 1 hr aswell . but you need to let it have a full dry overnight for 24 hrs .
3/ the clear enamel - gloss is the last set of coats , you need to leave it for 1 hr between coats - i did 4 final coats . but what i did was, do 2 coats , 1 hr between each , and let dry over night , and do the same - that way it dries hard .
and it makes a big difference to those who rush , and do 1 coat of primer / 1 coat of colour and 1 coat of gloss . it peals in the heat n just looks shit . if you take your time - you will definitly be satisfied .
as for the driver side arm rest , i think they are made to clip in and stay in sadly ! , but what i did was , if you look on the underside whilist it is positioned in . you will see 2 small clips to one long side , pop it out on an angle ! on one of the small sides there is a deep clip which needs to be push back as far as possible , then you have to snap the small side out of place . however it may snap , but it doesnt matter because it still clips in well with out any trouble .
thanks ,
i AM ACTUALLY THINKING OF DOING THIS TO THE R32, AS i JUST GOT SOME NICE LEATHER GEAR AND GEAR BOOTS OFF e-BAY !
NOW IT MAKES THE REST OF THE CAR LOOK DULL !!!!
dID YOU PREP THE SURFACE BEFORE USING THE PRIMER ? did you sand or clean with metho or just spray it all on ????
nice job by the way, Im planning on white I know you all think thats shit but your not driving my car are you.
Cheers
Dave
okay for ever one that is going to give this a shot - i sanded the hard surface with 400 gritt . and cleaned the surface with thinners .
SANDING is the most crucial part if you want a smooth gloss surface
i didnt sand between coats only before priming , cause it was unecessary. unless u have inperfections . i ended up doing 1 coat of metalic again because there was a fragment of shit on it lol.
in the midst of doing the same thing, that color looks awesome so used the same. i didnt prime it though, just a spray through as i didnt need to sand much other than the gear knob surround,
but applied 2 coats of color and 3 of clear
will post pics once the clear dries and i slap it back in the car
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • oops that seems much easier lol.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
