hey guys im a brand new skyline owner.
was lookin through this thread, some awesome results here and seeing as how my interior is a bit rough i just have to do this too.
ive got a bit of a noob question though... how do i remove the dash panels? i dont wanna break anything so i thought i'd ask first.
I'm thinking a dark silver might go well with a black skyline. What do you think?
thanks!
There are posts in teh DIY section... Anyways you need to pull the panels out, disconnect the main housing panel, i.e. various plugs that you just be able to clip out and that's about it really. For the driver's arm control removie the plug in the cup, unscrew it and pull it out carefully. If you need pics I could email them you. Good luck. To the thread starter.. once again this really is a fantastic thread. For the cost you get soo much more value and satisfaction. Cheers.
  • Replies 98
Had a go today, completly botched it, musn't have shaken the primer enough and was spitting everywhere, didn't use a high enough sandpaper so got fairly noticeable scratches everywhere.
So gunna goto supercheap tomorrow (hope they're open) get some 100,200,400,600 and 2000 grit sandpaper, another can of primer and the silver paint i picked out. Sand off all the old paint then work it up from 100 to 2000 grit to get a nice smooth surface, 2-3 coats of primer 2-3 coats of Mercury Silver or whatever it was and 2-3 coats of clear coating.
Will let you guys know how it turns out :sick:
EDIT: Just a quick question, how is everyone supporting the parts while they paint them, i've just had them lying on the ground, just so hard to get a nice even coating though, was going to hang it from the clothsline but it's right under a tree and didn't want shit falling off it
Edited by Rudager
yea i did mine last week and had them lyin on teh garage floor. Turned out fine. Make sure you spray one section at a time. Don attempt to spray a whole piece in one go with the finger on the nozzle. results don turn out good that way. Anyways supercheap will be open tomo ( i enquired, need to get a jack off them :D). good luck with your rejob.
hey I'm having trouble with this part here:
http://members.iinet.com.au/~ahmedk/07-04-07_1412.jpg
how can i disconnect the switch and light so that the panel can come out? also same problem with the antenna switch on the other side of the steering wheel.
on a side note, how many of you had missing screws behind the ashtray etc? :D
thanks!
Edited by ak_stylez
on a side note, how many of you had missing screws behind the ashtray etc? :thumbsup:
thanks!
The mirror switch i got a flathead screwdriver and lever'd it out from the front, just be careful not to put too much pressure on the dash plactic's.
thanks!
yup just lever it out with a flathead screw driver. It shouldnt take too much effort to get it out. Then disconnecthe plug for the mirror controllers. Am sure you'll have something similar for the alarm LED as well. And I dont know about others, but i have my ashtray screws intact :)
no need for a flathead. just reach behind and squeeze the clips on the back together. should make it pop out. no worries bout scratches that way. its how i did it from memory. if you want confirmation im gonna be pulling my dash out on either monday or tues. can tell u for sure then.
with the light, if it isnt obviously slotted in then just cut the wire behind it. no harm to ur alarm and easily reconnected later
  • 8 months later...
I finaly got around to doing mine, didn't use a clear coat and it shouldn't scratch. Went a bit further and painted the cluster surround and the climate control panel.
I want to paint the passenger air vent and all passenger window switches one day to finish it off, but this will do for now. :)
Before and after pics
P.S The Taco is stuffed i tried to fix it it worked for a day then stopped again doh!
XRAIDER i like that job man. any reason y u didnt go the clear on top? oh and you forgot the ashtray
Hey thanks buddy, I didn't want a clear coat mainly because of the sun reflection, and I ran out of paint just as I finished off the climate control panel, I'll do it when I do the passenger door switches and the passenger vent.
Cheers :D
  • 1 month later...
Just a quick one, I've read through the post and have not found the answer.
How are you taking the rubber coating off the dash parts before painting. I want to try the Model paint method that was mentioned previously in the thread.
Cheers.
i used sandpaper. bad idea this. lots of work and i had a lot of scratches left to fix afterwards. try either metho or turps. one or the other causes the rubber to deform, making it easy to remove. i found this out rite at the end.
  • 2 months later...
Well I've done my dash and other surrounds. Wont be doing it again in a hurry, but I did scratch it putting it back in...so maybe next Easter. Looks like I've gone a step further and done the door handles and side pockets of the door as well as the vents. I'd also like to do the demister vents, but have really had enough of this entire process!
I rubbed most of the rubber off by hand. Metho works and so does Acetone, but you still need to give it some elbow grease. Few coats of primer, few coats of paint and quite a few coats of acrylic top coat clear.
Main dash
Driver door
Passenger door
Fairly impressed with the result.
  • 7 months later...
  • 4 months later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
