Thanks Chris for the headsup.
Dropped the skirt off to Bruce today, he should have it back to new by Friday! He's even gonna try and pull the small dint out from under the door caused by the acco and fit the skirts back on for me.
Will post pics and give my recommendations once its back on!
Cheers!
no probs.
hes done a few bumpers for me and the end result was I couldnt see where he did them on the front.
ok skirts have been plastic welded and resprayed to brand new condition! Highly recommended if you need your OEM plastic parts repaired.
Name: Mobile Plastics & Vinyl repair (Bruce)
Address: 130 Ryans Rd, Nundah
Mobile: 0412457062
He's been doing this for 13 years! Now all I need is a new SAU sticker...anyone??? :laugh:
Mobile: 0412457062
Id ask Karen...
Ill be giving this guy a call to fix my front bumper after it met the front of the car trailer last Friday and cracked... :laugh:
Mobile: 0412457062
told ya he's good.
I'm going to see the sticker people (the ones that supply the officail ones) through the week so can nab one then if you like. I'm going to try and get one for the new van as well.
told ya he's good.
cool thx! spotted u in the van after i left bruce's shop...on sandgate rd 1:30pm..
The new batch of stickers is extremely close to the originals...the batch in the middle which were organised prior to the AGM in January 2006 were the different ones.
Karen, when you say extremely close meaning they're not exactly the same as the one i've got now?? Meaning I've got to buy 2?? :happy:
the skirts i got on mine look like factory ones i think, and i got them from carmate.com.
that sux dude, I have done the same thing came out of tight spot and forgot about the side of the car but luckily never damaged like that usually just some minor scratching....
Karen, when you say extremely close meaning they're not exactly the same as the one i've got now?? Meaning I've got to buy 2?? :)
I think you may have stickers which were from the "second" batch...if I can track one of those down, you can have it for free, otherwise if you want them to match I would suggest that you'll need 2. If you have seen Mel's 34 sedan, the stickers now look like that (which is how the original first batch looked).
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
