lan Party-Helensvale-3rd May
Guest neoGT-25
Hey everyone... how are we all?
i was in the mood for a lan and i GUESS WHAT! i found a flyer at school today :D WOOOO HOO!
its at the Helensvale Community Centre (31-35 Discovery Drive Helensvale) and on Saterday the 3rd of May (this weekend)
it runs from 9am untill 11pm (1 day lan)
there will be tournaments all day and they include...
*QUAKE 3
*CTF
*FFA
*WARCRAFT III
*MEDAL OF HONOR AA
*NEED 4 SPEED HOT PURSUIT 2
*COUNTER-STRIKE
*BATTLEFEILD 1942
-There is also servers for NON-TOURNAMENT gaming :)
they include...
*A Freelancer Realm
*Battlefield 1942 Desert Combat
*UT2003 Deathmatch
*Counterstrike War Server #1 & #2
Theres also a shop to buy food in the complex and bbq lunch and a pizza run for tea :)
But be quick... there is only 80 spots available and they are going quick!
Pricing is decent too :)
its $15 prepaid -OR- $18 on the day
(5 tickets prepaid for $60) so if theres 5 of us interested we can get it cheaper :)
gclanparty.com :))
hope to get some feedback and interest... :)
bye :burnout:
https://www.sau.com.au/forums/topic/14970-lan-party-helensvale-3rd-may/
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
