  • Replies 56
Posted Images
These are sooooooooooooo coool age. Cand you do a write up for these puppies in a nutshell? Or is it a little too complex for us photoshop novices??
that's right AGE... its about time you stepped out of the VIC section and did some tutes for the graphic design section.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794545
Ummmm, it's alot easier to do them tha it is to do a DIY on how to do them. ;)
You need some big pics of the actual pixar cars themselves, and cut and paste the best fitting eyes and mouth, then free transform/distort(ctrl T) them to fit. Then it's just a case of matching the color of the donor car with the cut and pasted parts.... thats the hard part, and black cars are the hardest, surprisingly yellow was very easy :)
I use lumination/replace color/brightness/contrast and matching color tools on photoshop. Also alot of history/eraser and eye dropper/paint brush tools as well. It a bit of work to match the color, but playing around with different tools, you'll sort it out. Best thing to do is start with a white or light colored car and play around with different tools. Ctrl Z is your friend :P
Here's some more.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794585
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
