When should i upgrade my fuel pump?
My mods are:
Apexi pod
CAI
FMIC
Turbo back exhaust
Boost controller set at 9psi
Power FC coming in a few weeks.
I think at the moment ill be making 165rwkw.
Will fitting lets say a walbro 255L jobbie increase the pressure to my injectors?
I have to change the voltage too dont i?
CHEERS
https://www.sau.com.au/forums/topic/149938-when-should-i-upgrade-my-fuel-pump/
mate walbro is bolt in replacement and very cheap to ad!... my fuel pump failed and cost me a motor. for the price of say 200 odd its well worth it and eventualy your gona need it. if you boost it i would ad a larger volume pump
talking from personal experience, at the same stage as u i had to change my fuel pump as it was on the brink of dying at that power level. Ive got a walbro, and it seems to be doing the job. either that or u can go for bosch 044 or 040. But defineitly if ur going to tune ur pfc soon, do the pump before this. No need for reg or injectors yet...and what ryan said :D
Edited by moonus
The walbro ones are good for 300rwkw arnt they?
See the FAQ/DIY section, there is a thread there showing you how. Up till 200rwkw I'd say with a new walbro you'd be OK without it. but after this you should think about doing the mod.
Thanks mate
Do i need to change the voltage on the pump to a higher voltage?
If your gonna upgrade then dont worry about the voltage relay. It's just a neat trick for people who cant afford to upgrade their standard pump
You should upgrade the voltage line, stock or aftermarket pump IMO.
The one problem most people have when installing a bigger pump, is it does not flow the fuel thats required/specified.
The reason being is that people use the factory wiring loom for the fuel pump, and it just doesnt let the pump see the power it needs.
For you "stockish" application... its no worry generally speaking.
However, later on down the track (6-12-18months) if you change turbo and suddenly run out of fuel... you wont remember that you didnt upgrade the volts back when you did the pump, which could turn into a pain trying to work it out :laugh:
Hence i would say just get it over and done with now and save time later... but thats just what i would do
Also that Walbro will not support 300rwkw. I would not go over 240rwkw.
I had about 250 odd and pulled the return line off to see how much was flowing back to the tank when revving hard on the dyno. The flow completely stopped!
However, later on down the track (6-12-18months) if you change turbo and suddenly run out of fuel... you wont remember that you didnt upgrade the volts back when you did the pump, which could turn into a pain trying to work it out :)
I hear what your saying........I guess I assumed that only an idiot would buy a 250KW pump for a 250KW application. Sorry for assuming
I'm letting my mechanic install my pump very soon, it's a bosch 040, do I just tell him to upgrade the voltage line also, or do i need to buy some specific wires/parts etc?
Read the FAQ, its not a case of upgrading the line [yes the mod is an upgrade, but the stock line remains the same]. What you are doing is supplying a direct voltage feed to the pump via a relay. You are using the stock wire as an on/off signal carrier.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
