Hi all,
I'm just after some opinions of what turbo's (read low mounts that bolt to stock manifolds) would be best for me. My motor is freshly built with all the good stuff, and just in the process of getting the head ported and installing some cams (still undecided, need suggestions as to what would work best)
I want 700awhp @ 2bar max and i was thinking either the HKS GT-RS or Trust T618Z, redline is set at 7500. What are peoples experiences with these turbo's, and what are their characterisitics i.e when do they come onto boost, how much can they flow @ what boost etc. Also the car's being set-up for track & hill climbs, so i require half decent response.
It'd be ideal if someone could suggest what turbo and cam combo will be best for my motor and power goal.
cheers
Shane
https://www.sau.com.au/forums/topic/149996-700whp-cams-turbos-for-built-2630/
either are a really big twin combo, i hope you dont expect them to come on anytime soon. do a search for twin GT-RS's i think 600HP has them and i think OZGTR97V tried them as well (said too big for 2.6, more like 2.8 stroker).
twin 2530s will give you good response and and really good midrange, plently for hill climbs etc. 700awhp is silly for hillclimbs. for hillclimbs boost repsonse is very very important, running large twin trust's or gt-rs's isn't going to cut it, far too laggy.
i would suggest focusing more on midrange and average power
yeah i saw the 3 litre later on. see if you can find out what a/r the gt-rs's are and aim a tiny bit lower than that perhaps? you should defintely do the split dumps/fronts (trust ones i think are the bee's knee's) and ensure a big exhaust from the cats back
Its GT-RS... and i remember you saying a while back you refused to pay the HKS pricetag... so...
Not sure how your gonna get yourself outta that McPickle.
I got ya on that one :)
But yeah, its GT-RS's for you Shane. There really isnt an option.
Even with a 26/30, over 500rwkw is not going to be your friend for hillclimbs ;)
Track, it should be alright, but you've still got another 20k to spend on brakes and suspension to get the power to the ground :P
Your basically trying to do what the Racepace GTR has done IMO, and that is a 6 figure car
already have hks split dumps, and hks tuned length front pipes, and 3.5inch cat back
thanks for the feedback :sleep:
I got ya on that one ;)
Track, it should be alright, but you've still got another 20k to spend on brakes and suspension to get the power to the ground :laugh:
hahah i know, and i still havnt changed my mind, its just easier to say hks gt-rs instead of the garrett spiel :)
So then the t618z arent in the same game as the gt-rs? i saw a dyno graph from an autobarn, showing the t618z on a built motor (more than likely stroker) with 280 10.8 cams, and made 300kw @ 4750 and 516kw @ 7500 (or near on). That's probably the figures id like, but if the gt-rs can make the same, and a bit earlier, thatd be the choice. what do you think?
All of this work so far has been out of my own pocket, so i'll be needing to source some form of 'sponsorship' down the track, for when the really expensive stuff breaks :P
thanks for the feedback ;)
All of this work so far has been out of my own pocket, so i'll be needing to source some form of 'sponsorship' down the track, for when the really expensive stuff brakes :P
Have you thought about Garrett 2860R -10's (707160-10) ? Spec-wise they appear to be very similar to the GT-RS's.
http://homepage.ntlworld.com/tbroom/Turbos.htm
Edited by mambastu
thanks for the link, great site! yep they are the ones id be going if i were to go the 'gt-rs' route.
Heres that dyno graph i mentioned earlier
have you thought about things like brakes, suspension, diff, gearbox, transfer case, etc etc all the drivetrain parts? as running 500awkw on stock gtr running gear thats 16 years old is a bit of a concern.
You need bridged mainfolds for those size low mounts. Dirtgarge had or have GT-RS
http://www.skylinesaustralia.com/forums/in...howtopic=148285
If that is a graph of there car they had GT-RS turbos last time i heard.
Sorry mate but I don't think thats Paul and Staceys graph
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
