Anyone know of a car storage place in Perth NOR?
Most places I've rung have no vacancies and are expensive.
Been looking after my Brother in Laws WRX for 2 years while he works away and want my garage space back.
Alternatively anyone want a '03 WRX (red) with 24,000kms for $30k?
I think he should sell it personally but yards didn't offer enough.
https://www.sau.com.au/forums/topic/150082-car-storage/
Why not just take it to a storage place? My work uses a storage area in subiaco with a lockable garage door (easily enough room to fit a car) and I dont thinnk it is all that expensive. We keep 40-50k worth of stock there so a 30k car shouldn;t be an issue???
There is a storage place in Joondalup near Toys R Us, one just near the Hutton St exit on the mitchell fwy... pleanty of these places around.
https://www.sau.com.au/forums/topic/150082-car-storage/#findComment-2797866
The one in Joondalup is $340 per month and have been on a waiting list for 3 months there
https://www.sau.com.au/forums/topic/150082-car-storage/#findComment-2804365
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
