Hey Ian,
I will be selling my GReddy boost guage soon if your keen. Next time your out at dinner ask me for a look at the mounting of it. It isn't the most aesthetic of mounting positions but if you want to keep an eye on your boost it's hard to find a better spot without hindering your vision of the road ahead.
https://www.sau.com.au/forums/topic/150161-gauges/page/2/#findComment-2801677
Buy a boost controller that tells you the boost?
I have both. I find that trying to view my boost on the controller as it hits peak while driving is a suicide mission due to the positioning of the controller. I wouldn't want to mount the controller any higher either due to the amount of light they throw off.
https://www.sau.com.au/forums/topic/150161-gauges/page/2/#findComment-2801696
Yeah yours is in a hard spot, I can see mine nice and easy but...not that I ever look.
https://www.sau.com.au/forums/topic/150161-gauges/page/2/#findComment-2801726
here ian, have a look at this. this part is for an mx5 but this is probably the best idea for you
that is an actual replacement cover (not mounted correctly) try this site to see if they have anyhting for you Japan Parts you can find a heap of stuff on this site to give you a good idea do a search under meters and guages.
thats prob the best position IMO anyway
https://www.sau.com.au/forums/topic/150161-gauges/page/2/#findComment-2802202
