Hey guys
i kno how hard parts can be to find for manual conversions (ie like my 31.........manual parts are gettin thin on the ground). mate of mine is about to pay for a r32 gtst m spec 4 door in auto form.
wants to do a manual conversion. I know RB20 box prices, and i kno that RB30 manual flywheels fit. its just everything else im not sure of, and he wants an idea of part prices and what would be needed. i think i still hav the crossmember from the 20 box i bought, but im not 100% sure where it is LOL
any help would be great, as i'll prob end up helpin him do it
Whats the car used for?
Street duties? He may be better off with a 3k stall convertor and shift kit. Push the boost in to it and the manual will have a damn hard time keeping up with it off the line.
Auto's are always better for straight line. If thats what he enjoys and does most keep the auto. >_<
i think i have a 32 manual crossmember laying around..
remember my thread on 31 forums. massive write up, simu;lar thing for most skylines.
remember to remove auto spigot bush out of the rear of the crank and insert the porus bronze spigot into the crank for the input shaft of the box, if you dont, youll have to pull the box back out anyways...
if you need any help ive done about 5 manual conversions.
There's one bloke here thats dropping his car in today and is being SLUGGED $4800 for a drive in drive out auto to manual conversion with an Rb20t gearbox.
$1400 drive in drive out is well priced. All most too well when you consider the price of a new clutch, the box, centre console, pedal box, tail shaft, clutch master and slave. I would expect up around 2k to 2.5k.
yeh, used that when i did mine, pete (66 skyline gt) helped me out
cost me 1000 just in parts and i got a few freebies
Yeah, that's what I got quoted 1.5yrs ago, so costs may have changed? And they also supply a 2nd hand stock clutch, it would help if you brought a new aftermarket clutch to them, the stock ones dont last too long anyway.
Edited by salad
Boostworx will do it for just over 2 and a half with a new xtreme hd clutch.. got mine done and it drives absolutely awesome..
how about a stagea manual conversion?
what do they cost?
Edited by Tommmo
Everything I've read on Stag manual conversions so far leads me to believe it's not worth the trouble.
For starters you need a R33 GTR gbox. $$$
Just get a later model manual to begin with.
Edited by Oosh
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
