hey guys my mates got an r33 series 2, hes gota full exhaust filter and the standard bov is blocked, he wants to get his car dosing loud like i mean loud and have the vl kind of dose and id appriciate it if someone can tell me wat he needs to do, hes got a full sized hybrid front mount cooler but not fitted, wat else wud he need ?
https://www.sau.com.au/forums/topic/150684-dose-pipe/
  • Replies 70
lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots and lots of intercooler pipework, the biggest truck core you can find and metal pipework for the induction piping. larger compressor wheel will probably chop more so be sure to run a really big expensive bush bearing pesant spec T04 1980's turbo, run a stack load of boost, over 1 bar at least and throttle off and let it chop away.
https://www.sau.com.au/forums/topic/150684-dose-pipe/#findComment-2804670
I tell ya... to ask such a question should earn just a joking level ban :D
How dare i do this... but... it all can be found here.
http://www.calaisturbo.com.au/showthread.php?t=89365
Need this thread not go on much longer.
https://www.sau.com.au/forums/topic/150684-dose-pipe/#findComment-2804720
where did he buy his exhaust filter from?
how much was it?
was he able to fit it himself, or did he have to pay someone to do it? :D
(sorry ash, I know how much you love these threads) :(
https://www.sau.com.au/forums/topic/150684-dose-pipe/#findComment-2804727
lol, howd you do that, the chicks would dig it!
just hade to change quite a fue things but putin the AFM in the cooler pipin wont get you that sound and yeh the chicks love that sound man when you go driving people look around and expect to see a VL but they see my skyline its the best looks eva when its hittin 18psi its so loud haha its mint as
https://www.sau.com.au/forums/topic/150684-dose-pipe/#findComment-2804816
What does it matter if its bush or ball bearing? ALL trust turbos are Bush ...
https://www.sau.com.au/forums/topic/150684-dose-pipe/#findComment-2804849
is it really good for the AFM to have boost pressed apon its plastic casing?
and when you say "change quite a few things" like?
It is fine, it will give a better idle...
Ask Dr.Drift ( SAM ) He does this to all his customers cars now after many years of using the AFM before the turbo he now preffer's it attached with the intercooler piping.
https://www.sau.com.au/forums/topic/150684-dose-pipe/#findComment-2804867
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
