personally i would do neither of the above...... what i have done is i have a white 32 and i removed the wing after i did i went and got some similar coloured sign making contact from scotchline(any place that tints windows or does sticky signs does stock it)and i just put that over the holes they have heaps of colours in stock so u can get something close..... in pics u cant even tell mine had a wing......but still this is a short term fix.... eventually u will have to get the holes WELDED up the re paint the boot......
i have taken the wing off mine, looks heaps better i think.
white r32 is right , to do it properly they gotta be welded underneath and putty on top.
you could use fibreglass under instead of welding but i heard after a while u get a dip in the whole that u can see
i cant affors to do it properly yet so the wings goin back on.
off the topic a lil
mm2death wat mods have u done to your 32?
i use to just leave the holes there, no-one can tell unless they came right up to it and look at it.
i put the R wing back on last week as it seems everyone in perth now has it off... bah
it looks more agressive now with it on :P
Shaun
Radium,
Copycat, i put mine back on last week after i broke it the first week i had the car. Took a fair bit of modding to get it back on. GTR wing looks the goods, especially with the small lip that runs along the boot.
I like it when its on AND off, kinda hard to decide which one i like more. Looks a bit bunky with gaffa tape on the boot tho.
Red17
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
