oh i thought it said that it was a repairable write off.
Must be seeing things....
do you guy think that its worth buying any damaged car and repairing it?
I mean a car with less damage obviously.
I'm going to keep searching for slightly damaged cars and hope i can get a bargain (and not a lemon).
if u really want to do something like that, why not send it to thailand/indonesia it will cost u lot less in labour charges. eg u r living in NZ, get a wreck/damaged from Japan, but send it to Thailand/Indonesia/or even japan etc to get the damage repaired. keep in NZ for the rest of 1 year, and then bring it in as a Personal import. perfect (well for u, not someone who buys it off you)
Bec: if it was not too damaged i would be doing most of the work myself (i want to learn how to fix a car etc.)
Fuzzy scuz: I wouldn't mind doing that but I dont think many people would be looking for brand new rex parts out of this model (or am i thinking wrong??)
Ziad: I'd prefer fixing the car myself to learn the car etc. and to learn the basics about cars in general.
If i find another car (without any structural damage) i will post up and everyone can give me their opinion.
Thanks for all your help
You are choosing the wrong type of damaged cars to learn with :huh:.
This is waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaay beyond a beginner's level for repair. Hell some people that have been in the trade for 10yrs may find this project a task and a half to complete properly.
You need to find something with very minor accident damage :P
You should probably start on a slightly damaged Silvia, with mild panel damage, maybe a pushed-in radiator support. This way parts are cheap and it wouldn't be too hard to fix.
Even then, you would at least need to know how to weld. Trust me, having fixed two damaged cars already, it's never worth it in the end.
Unless you can get all the parts you need cheap or free, then don't bother with expensive cars, or it will prove to be a very expensive lesson.
I'm on my third repair now and just can't be bothered. Alligning guards, bonnets, cutting, straightening, it's just a pain. Hence, I've just taken my car to the panel beaters this time.
With regards to switching plates, it's not that easy. If the car was declared a write-off, it will need to get a VIV certificate before it can be re-registered. They are used to dealing with all the Habib's from Broady, so they know exactly what to look for. They thoroughly check that the numbers are legitimate and not swapped over, ensure you have receipts for parts and that panel work was actually completed.
Anyway, good look with your endeavours.
Yeah, not an amateurs repair by any means.
Also, with that much damage, gearbox casings could be damaged/split. all sorts of stuff that you visually cant see until you pull all the parts out.
Suddenly a cheap wreck your trying to sell parts from, isnt worth anything as the parts themselves are damaged to a point of no return
I didn't mean that i would be using this car to learn how to repair with, but i meant that i wanted to learn how to repair cars etc., by repairing one to start off with.
If a slightly damaged silvia would be the way to go, anyone have one or know who has one for sale???
I know someone in the industry that could help me out, and get me cheaper parts.
:laugh:
So you where going to buy this car, keep it in storage for a few years, till you have gained enough experience to repair it?
In you first post you stated:
Was looking at getting this car and repairing it.
Do you guys think it would be worth it?
I'm looking to get a cheap car, and i was thinking that i could get a newer car that was damaged and i could repair it, thus making it cheaper than if i was to buy it in good condition.
Then above you stated:
Which tells me you wanted to learn how to fix cars using this wreck.
Best way to learn would be through an apprenticeship. Then start off small and cheap, something like a datto, rx3, silvia, etc
AL:
I said that i wanted to buy this car, repair it, and by repairing it, i would learn some of the basics about cars etc.
I in no way said that i would be buying the car, keeping it in storage and then repairing it once i had gained enough experience
My previous post was in reply to this.
I am merely stating that there is nothing basic about repairing this car.
To learn the basics you need to start with basic accident damage, not write-offs, involving highly technical cars.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
