Is an after market chip really that good of a bang for your buck mod on a resonabley stock car ? Cause I'm looking at getting a FMIC in the very near future (as well as getting my brakes done, machined and new pads) and then upping the boost a bit with a bleed valve. Then hopefully getting the dump pipe/front pipe done with a 3 1/4|1/2 depending on how much moneys left over.
The 32 ECU's are remapable (to a certain degree) aren't they ? Cause I read in Zoom a while ago, with a fuel pump, boost valve (to 14 psi though) and a remap they got 160rwkw on a stock 32gts-t.
Do you think a PFC for $2000 would be the best dollars spent though ? Currently all i've got as far as power performance is a catback zorst. Getting a bleeder shortly though.
I'm doing work on ecu's atm on r32's using an s-afc as well I need some dyno time to see how it goes the best bang for your buck mod you could do is to bolt the turbo from a vg 30 or an rb25 and you will make 170 rwkw hp at least at around 10-12 psi but I'd get a bigger fuel pump as well and a bigger fmic you don't need to spend 2k on an fmic if you only going to chase 170-180 rwkw you just need something bigger than what you have.
a s/hand one will do.
meggala
Well I'm looking at getting a FMIC at the minute, i'm looking at getting a decent sized cooler as i'm looking at around 200rwkw in the future. So I don't want to have to do it again. I will be looking at getting a VG30 turbo in the next round of semi/major mods. Probably with a fuel pump in between.
bump that - get a T04, thats what i am probably gunna do. :P
I am getting my S-AFC soon too, can't wait!! :P
Then i will tune for 12psi and i should be getting ~180rwkw (I am gettin 162rwkw now on 9psi with no S-AFC).
Christian
and
NOZILR!!
OK guys - that's really good feedback -
i can see merit in FMIC and boost contoller straight up. Gives colder (more dense) air and more boost (without detination right ??) Then ECU 'cause factory one is Shiet. I wanna know what dump pipe is, and what is the benefit ?? Then, bigger turbo (makes sense - more O2) After that you need more fuel right - ECU can only do so much so injectors need to be bigger right ??
Has anyone done a short shifter mod ?? Don't know how much benefit on the 1/4 it would be, but sounds like FUN.
PRANK - is there a local shop to Nth Beaches ??? Where do you go ??
OH - BTW - U F'd up my compliance papers to Canberra - sent copies instead of originals - LET IT BE KNOWN -they only accept originals - Have to make up the StfUp by lot of Canberra brown nosing. Hopefull I will have BEAST on the road by late AUG.
Cheers All.
BF
Originally posted by [ryan]
catch can is the thing that catches the oil the bov spits out rite?
i like ndr's home-made catch can haha..
No sorry Ryan,,,A catch tank is just a remote oil breather tank that stops oil mist from re-entering the inlet side of things.......Nothing to to do with a Bov at all..........
Neil.
Dump Pipe is the first part of the exhaust off the turbo - they make a big difference when you get an after market one.. i have a 3 1/4" dump pipe (HPC coated - this lowers the heat emmitted from the dump pipe and keeps engine bay temps down..)
There are some shops, but i take mine to my mate in Castle Hill - Hills Motorsports, he has done everything to my car so far and knows his ****, a few people from the boards take to him.
Cheers All.
BF
Thats a bummer dude - how much longer will this cause it to be?
Christian
Hopefully, I can fix before the car arrives - Will be moving heaven and earth to make it happen -
I work in Castle Hill - So maybe Hills is the go - Have been looking at UAS, but yeah,,,,
Cheers dude,
So dump pipe is like a BIG exhaust manifold ??? Like headers ??? Am i on the right track ??? Lets gas out quicker than standard ???/
BF
Neil.
ahhhhhhhhh ok gotcha. whats that thing u've got then that collects the oil!?
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
