  • Replies 94
Posted Images
Does the fact that isnt one detailed picture worry you?
because it worries me.
You cant see anything clearly.
without far more decent pics, i say stay away.
whats the setup anyway?
i made 270rwkw on pulp and 369rwkw on 104 octane with the stock item with as good response as those with front facing
you made almost 100kw's more using 104 octane fuel?
I was looking at them last night they look very cheapo, would need alot of cleaning up. Theres a guy in geelong i think selling them on ebay too, he has better pics.....
The guy in Geelong selling these on ebay even says he has done before and after dyno runs with a 14kw increase with 28nm increase in torque...
For $300 I reckon it would be a pretty good upgrade just to clean up the engine bay a bit..... get rid of the intercooler piping, clear access to spark plugs, get rid of cross over pipe and relocate rubber hoses...
Can you get cast aluminium smoothed and polished ok?
I am gettig one this afternoon. Will need to probably clean it up with a dremel but arounf the water jackets but meh.
At least I can run top feed injectors now without having to make some gay spacer up for the stock plennum. Thats my main reason for getting it. Also save on the piping.
and no I couldn't have just got side feed injectors I aleady had 700cc top feeds doing nothing thats why.
Anyway I have a pretty decent camera now so when I get myn I can put some really hi res pics up if enough people are keen to see one up really close.
Edited by James_03
Id be very interested in finding out the quality of these items, If it doesn not cause any of my cylinders leaning out then i will buy one. I know a guy wiht a online store that is starting up http://www.iconautoworkz.com.au He will be able to do us a group buy cheap!
Any one got any info on if it will cause any uneaven leaning out?
Posts to: Australia
Item location: HongKong,ShangHai, China
Bank: Bank of Melbourne
BSB: 733-178
A/c NO.: 588-444 A/C Name: Ying Wei
Sounds way to suss for me, i've heard of hepas of scams like that.
I've also heard that the intake manifolds u get of ebay liek the greedy style copies "which this one appears to be" are of poor quality and the wall thickness is minimal which can result in cracks!
Exhausts manifolds on the other hand from ebey are ok i've heard.
Those things are $70 US a peice when you buy over 50 lol I noticed some chinese import/export website and i sent them an email just to see what they said and thats the price i got.
As far as those sorts of items it's a little risky. I purchased a low mount turbo manifold from some sonofabitch (not naming any names) on ebay and the lovely welds they had on the manifold (pertruding welds) came off from the inside and went through my brand new 15minute used turbo..... lovely :happy:
Learnt my lesson the hard way.
"STAYAWAYFROMEBAY" :sorcerer:
I certainly wouldn't put one on without serious cleaning up first. Check here to see pics of my SR20 manifold
http://forum.silviansw.com/viewtopic.php?t...hlight=manifold The before pics still had about 10 hrs worth of clean up. I modded the manifold to take a bigger throttle body, which allowed better access so I cleaned it up some more.
I used a drill and a long shaft I bought at bunnings and some stones. I have had several areas on the manifold welded up, the casting is not brilliant, but for the money if your prepared to put the effort in it can save some cash.
Just wondering if the manifold required welding up, or did you get it done as a preventative measure. as far as the internal finish is concerned, it is certainly no worse than the original manifold, but a clean up certainly wont hurt.
I bought one off ebay, actually the same one as posted above. Unfortunately it arrived damaged, most probably through the poor packaging and will be sent back to the supplier. So far he has been good about the whole deal, so lets see what happens.
You get what you pay for. I was aware of the poor quality, as i have seen one on another car, at my mechanic's w/shop. I plan to linish and sand the outer surface to make it smoother b4 powder coating it. It should look pretty neat by the end of it.
Below are the pics i took, to right a report to the seller.
I'm posting it here not to ruin your gb.
Mine was packed the same and the first 3 pics demonstrates the recieved condition of the poorly packaged item. Hope you don't get any dramas :)
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
