  • 7 months later...
A welded diff can be stronger than an LSD, if you weld it properly. Minispools will definitely be stronger, however the driveline harshness around tight corners or dropping the clutch can break driveshafts instead, if your car has weak ones.
Handling definitely suffers. No idea whether V8 supercars run spools because their LSDs shit themselves or just for financial reasons (chuck a spool in and drive around it vs rebuild LSD every race meet).
Locked diffs oversteer on the throttle and understeer off the throttle. The danger in the former is obvious, the danger in the latter is if you overcook a corner and jump on the brakes you can find yourself heading straight for the armco. LSDs handle much, MUCH better.
https://www.sau.com.au/forums/topic/151701-mini-spool/#findComment-3325160
V8's do them not for financial reasons... when it colst millions to run a team, rebuilding an LSD every meet pales into comparison. they run them for reliability and because they do work.
it is possible to have a well handling car with a locked diff..... they dont all under steer on throttle and snap oversteer off throttle..
https://www.sau.com.au/forums/topic/151701-mini-spool/#findComment-3325349
welded diffs are a very dodge but cheap way of locking the diff, i wuldnt be puttin a mini spool into an i.r.s nissan anytime soon, not unless you wana do half shafts every week. either shim the std lsd or put a 1.5-2way etc in it. only 2 options imho.
https://www.sau.com.au/forums/topic/151701-mini-spool/#findComment-3325619
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
