I've recently started looking into a car stereo and so far I've pencilled in around $1600 worth of stuff. But they're of mixed manufacturers.
12" pioneer sub
JL splits
Alpine mono block amp
JVC double din screen CD/DVD (WHICH WAS A STEAL for
$650!
Just wondering if having different names would affect anything? I chose these due to prices...
https://www.sau.com.au/forums/topic/151714-mixing-audio-manufacturers/
12" pioneer sub
JL splits
$650!
As long as its all quality stuff I wouldnt be worried, so therfore you should be fine. Where alot of people go wrong is spend big on speakers and subs, then buy a $100 1200w boss audio amp from strathfield and then wonder why it sounds sh1t.
hahah thanks for the piece of mind, I can sleep easy now. All I need to do now is buy it and install them.
Cheers guys!
I agree, from a sound perspective, it makes no difference.
From a resale perspective, if you're planning on keeping the car, depreciation will balance things out.
A single brand "looks" better to the buyer-but if you've got a great price for the gear-enjoy it.
There's no technical reason why consumer gear can't be mixed and matched, provided you follow basic guidelines:
1) any distortion means you're driving some component (head/amp/driver) too hard - back off before you melt something
2) it's a misnomer that a 50W amp can't blow 100W drivers - distortion kills lots of things - refer point 1.
3) based on point 2, it's better to have an amp that's slightly higher power than your speakers, as that way you're likely to be driving clean power up until the clipping point of the speakers (ie your speakers clip before your amps do). Nothing blows a driver like clipping at the driver's limit. Tricky with splits as you don't really know the power split between woofer and tweeter (same issue with coax drivers) - again, if you hear distortion, turn down the volume.
4) for truly staggering sound you can't go past active crossovers - a separate amp per driver, with an electronic crossover splitting the sound at low level feeding each amp. More expensive in amps and a crossover.
Fantastic sound but in my expeience (in home stereos - I haven't gone nuts in my car stereo), drivers (esp tweeters) tend to destroy themselves occasionally (you have a power amp at full gain connected directly to each driver-any glitches get amplified and go through the driver voicecoil).
The reasons for going active are numerous but not necessarily warranted in a car unless you want ultimate sound.
cheers
Mike
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
