Sorry guys, i don't have a photo but i saw a white R34 coupe at Macca's Nunawading on Sunday morning that had a flush boot spoiler (no posts) that protruded about 100mm past the boot. Was wondering if anyone new what it could be and if they had any pics of it. Thanks heaps.
https://www.sau.com.au/forums/topic/151821-which-r34-spoiler-is-this/
Just wondering about the legality of that, it looks nice though,
Provided you still have a 3rd brake light (which i think is mounted in the boot lid on a 34 >_< ) that wing would be legal, as it looks to be completely made from fibre glass, even the supports.
nah al, any part that protrudes beyond factory bodywork is illegal...
eg where a "T" style wing protrudes either side of the bodywork it is illegal.
there used to be all the regulations on the vicroads website, but the buggers have taken them off or I can't find them anymore.
Don't forget the gaurds buldge out. My wing sits in a similar manner, but is still within the width of the guards, near the wheels.
Judging from that pic alone, i still say it may be legal.
PS: I know mine is illegal, as it is fully aluminium :)
From memory, the tomei drag car (the yellow 1 that was stolen) has a spoiler similar to that....thats just going from memory, so i'll try and find a pic to make sure I didn't dream it up
Edit: Nope, doesn't have 1... my mistake
Is this it?
It was like the sedan one but protruded back further, never seen one on these forums.
Hey,
Any ideas for other places to get that sort of lip picture cause thats the one I am looking for... Only seen it on a standard R34 2000 model GT.
Drew.
Is this it?
I was on the other side of the road as it drove past, think that could be it although it was all white and not sure if it had the separate wing at the back but then again maybe it did. Thanks heaps for your help.
Hey,
Drew.
Yep, Powerplay has this one but seems to defeat the purpose as the S2 R34 boot spoiler totally covered the factory boot brake light (cos it rusts) and this one has a hole in it to expose the factory brake light.
Wonder if it will fit series 1 then? Cause I already have the break light but it is lower down. I like the rear bar on that sedan wish I could get mine to look like that, thats the only thing i tend not to like on the sedan is the blinkers nad reversing lights i like the way the coupe has em setup way better.
There was one of those rear bars on E-bay for a few weeks, only wanted $170 for it and it was new.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
