Sorry guys, i don't have a photo but i saw a white R34 coupe at Macca's Nunawading on Sunday morning that had a flush boot spoiler (no posts) that protruded about 100mm past the boot. Was wondering if anyone new what it could be and if they had any pics of it. Thanks heaps.
https://www.sau.com.au/forums/topic/151821-which-r34-spoiler-is-this/
Just wondering about the legality of that, it looks nice though,
Provided you still have a 3rd brake light (which i think is mounted in the boot lid on a 34 >_< ) that wing would be legal, as it looks to be completely made from fibre glass, even the supports.
nah al, any part that protrudes beyond factory bodywork is illegal...
eg where a "T" style wing protrudes either side of the bodywork it is illegal.
there used to be all the regulations on the vicroads website, but the buggers have taken them off or I can't find them anymore.
Don't forget the gaurds buldge out. My wing sits in a similar manner, but is still within the width of the guards, near the wheels.
Judging from that pic alone, i still say it may be legal.
PS: I know mine is illegal, as it is fully aluminium :)
From memory, the tomei drag car (the yellow 1 that was stolen) has a spoiler similar to that....thats just going from memory, so i'll try and find a pic to make sure I didn't dream it up
Edit: Nope, doesn't have 1... my mistake
Is this it?
It was like the sedan one but protruded back further, never seen one on these forums.
Hey,
Any ideas for other places to get that sort of lip picture cause thats the one I am looking for... Only seen it on a standard R34 2000 model GT.
Drew.
Is this it?
I was on the other side of the road as it drove past, think that could be it although it was all white and not sure if it had the separate wing at the back but then again maybe it did. Thanks heaps for your help.
Hey,
Drew.
Yep, Powerplay has this one but seems to defeat the purpose as the S2 R34 boot spoiler totally covered the factory boot brake light (cos it rusts) and this one has a hole in it to expose the factory brake light.
Wonder if it will fit series 1 then? Cause I already have the break light but it is lower down. I like the rear bar on that sedan wish I could get mine to look like that, thats the only thing i tend not to like on the sedan is the blinkers nad reversing lights i like the way the coupe has em setup way better.
There was one of those rear bars on E-bay for a few weeks, only wanted $170 for it and it was new.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
