Seems like fairly low MPH for nearly 500rwkw?
I ran 124mph with 300rwkw.
What sort of tyres did you run?
Cheers,
matt
Anyways i dont care if people believe it or not
i did a 10.8 @129MPH and when you do the maths it works out.
  • Replies 113
so what is the best ECU for under 2000?
Best ECU under $2000
Hydra
Same features as haltech
Knock sensor Feature
plug n play
Boost Control (easy to use)
Or Microtech
No knock sensor feature
no boost control
Cheers,
matt
well actually when i run the car
i was using 502 rwhp and 35 shot of nitrous
so prob around 540 rwhp
car weighed 1420 kgs
seems like a lot of wanking about which ECU is better.
We have seen good numbers from most of the ECUs mentioned...so get over it. For 1k the PFC is not a shit ECU.
Ask ur tuner and get something that suits your budget and works well with your other mods. No point spending 3k on a ECU and having a fairly stock setup.
As far as I can see for street driven modded cars thre PFC is the best value for money.
4) use oil for AUSTRALIA MOTOR CONDITIONS
please tell me what oil u are running brand and model. Australian conditions? wouldn't it be more suitable to use oil for the abient temp and DRIVING conditions?
Penrite hpr15
If people actually know how to use the microtech
It is the cheapest and best ecu on the market
Power fc ecus are rubbish cause they chose to keep the AFM instead of changing to a map sensor such as every other brand ecu
If Power FC's are so "rubbish" then why are half of the people on this forum using them???
I have heard and read nothing but good things when it comes to Power FC's which is why i purchased one for myself.
By the way this thread wasnt about ecu vs ecu, the guy asked a question "how much power can a r33 rb25 handle?" in my mind there is no right or wrong answer, it all comes down to how well it is tuned, the quality of the parts used, the conditon of the engine etc etc, i have heard of lots of people making huge power on stock internal rb25's ,there is a r33 over here that has very similar mods to MR331307 , he is also using a gt35/40 from what i have been told, and is said to be making 450rwkw on stock internals ,it ran a 10.7 a few months back (not sure what MPH, was completly stock bodied aswell)
IMO 300rwkw is a very nice number for a street driven stock internal rb25det r33.
well
i guess that im not the only one then am i
everyone should try it
well
Yeah i dont doubt that you made the power you said you did, i watched all the vids on your site and read your whole thread aswell, was very impressed lol.
There seems to be lots of guys in the usa putting rb25's into silvias at the moment and making very decent power reliable to.
Penrite hpr15
its cold start Cst rating is 195!! hope u drive it under 3k for 15min...even at at op temp its visc rating is 23, thats a thick oil.
However it HTHS rating is 6.1! thats massive..good for decent track work
Another factor is their HPR range is Semi-Sync...not that I'm against semis cos new semis are close to the full syncs.
For hard work this oil would be good i.e. the track...for a daily driver its not my first choice.
ROYAL PURPLE 10W40 all the way! :)
As for ECU, it will only ever be as good as the tuner... however as far as getting the upmost performance, economy and realiability, a MAP sensor based ECU such as Haltech are recommended by every tuner i have spoken to... Apexi PFC is a great plug and play unit however is limited in some of the advanced finer tuning sectors from what i have been told...
Cheers
but how many people actually use it
lot of people here in wa use the d-jetro,x-speed in wa are the best in wa for tuning the powerfc.anthony scali's skyline gtr (888hp at the wheels).people would know that car(n4speed).i think the top 5 skylines horsepower wise in wa all use the d-jetro,x-speed has also developed the d-jetro successfully to use in auto skylines. :)
Autos work fine with plug and plays but with firmer shift and no timing retard or rev limit on WOT shifts but the V500 car do this with a little wiring change and basic ECU setup.
i beg to differ.
if i stall it up at the drags etc,
on two thirds throttle my pfc bounces on the limiter in second gear once or twice then slams into third.
if i then plant my foot it will do the same in third and then try to change into overdrive.
all without moving forward.
why would it cancel the rev limiter on changes?
wheres sydneykid when you need him on the afm vs map sensor debate
my tuner here in nz who's one of the best in the country says afm's are more accurate and the power fc is a great computer.
then i guess because you have an rb25 with 377rwkws that means everything you say is gospel.
there is a guy here who has 450rwkws on the stock internals and ran 10.65 so it definitley can be done
Hey mate
Just wondering who your tuner is??
Yup the grey Japanese Performance series 1 r33 was the one i was talking about earlier, done 10.7 or 10.65 at masterton motorplex, pretty impressive, sounded bloody amazing too!!
my new rb25 is making 757 rwhp without nitrous
behind a auto
Not wanting to get into an argument here, but I don't believe electronics are the japanese strong point. They excel from a basic engineering standpoint with the build quality and tolerances of their motors. Look at most Jap vs Aussie motors and you'll see that the Ford/holden built motors are the ones who use/leak oil etc, while it's the japanese cars that always have failing electronic components (oddly enough). PFC's are so popular because the Japanese have been using them for a long time & get easy and consistant results with them but really they are just a basic adjustable standard syle ecu. Then look at some of the aussie cars using Shit low tech motors and Aussie made ECU's and tuning knowhow, and they break all the rules. V8 supercars is a good example of a basically shit motor tuned within a inch of it's own life.
Short answer is PFC = Easy option/Path well travelled
Don't mean to offend anyone. Just my two cents.... I realise this may be considered an unfair generalisation, but it rings true in a lot of cases
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
