Hi everyone.
I have a internally standard RB25. Just wondering what a safe RPM is for it.
Standard Cams
GT3037 550hp turbo (.82 rear) 18psi boost
Injectors (555cc)
Excellent Tune that shows no signs of knock at all
Full exhaust etc.
How safely can I rev it, and what would be a good limit? 7500? 8000?
It pulls all the way to 7000rpm, and wants to keep going. (ie, doesn't run out of puff)
Any hints suggestions, weak points etc would be good.
Edited by The Mafia
https://www.sau.com.au/forums/topic/151914-rpm-opinions/
But basically no further than 8K as that is about the limit of the top end. If that thing is making decent power at 3K then you should be shifting a bit shorter to use it instead of revving the ring out of it in the interests of longevity.
https://www.sau.com.au/forums/topic/151914-rpm-opinions/#findComment-2826190
I'd be more inclined to worry about the rod bolts letting go or something similar.
I ran mine at 8000 with rods/bolts in the bottom end and it was ok.
But if you want to err on the side of caution i would stick to ~7200/7300
https://www.sau.com.au/forums/topic/151914-rpm-opinions/#findComment-2826922
7500 will be fine Jono unless there is already a fatigue flaw present, and you would no doubt have found out by now. In fact plenty run to 8K without issues but again, that is the limit of the head before the hydraulic lifters start to give problems and float, not a bottom end problem.
So what experience hve you had with rods/bolts letting go in RB25's Ash? It isn't a common failure by any means.
https://www.sau.com.au/forums/topic/151914-rpm-opinions/#findComment-2827131
If you want it to last 7500
if not over that
I used to rev mine to 8000 8200
didnt snap any rod bolts
just bent a rod
Like a BANANA hahahaha
https://www.sau.com.au/forums/topic/151914-rpm-opinions/#findComment-2827318
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
