Have owned a mint r33 gtr vspec for 6 mths . Imported it from the Japan.
Has a full weldina cruising exhaust system from the turbos,400r nismo body kit. nismo gauges ,turbo timer and a few other visual enhancements. I put a KN panel filter and some LMGT1 18x10 +20 wheels with falken 275/35 tyres.
Changed all the oil for redline .The car goes really well as it should at 38k k on the odometer.
The engine is in GC with good even compression on all six cylinders.
I want to increase power to around 300kw and would like it to be very responsive . not interested in bulk power.
From my research on turbos it appears that either garrett 2860Rs (HKS gtss)
or trust T517z 8.0cm2 are good torque monsters. The gtss are double roller bearings and water cooled and the trust jobs are sleeve brgs and not water cooled. I think the trust jobs come on faster though.From what everyone says.
Would like to fit a apexi power fc with the boost controller kit as well which is self learning.
Also want to fit new cam pulleys ,crank pulley and tensioner rollers with a stronger toda belt , so as to guarantee the drive train.
Want to leave interior stock apart from the FC controller I do not want any extra gauges.
Dont do burn outs just fast windy roads. Would the clutch last?.
This is not a everyday driver just my obsessional toy. (top grammar)
I would really appreciate any input on this and welcome any suggestions
before I commit coin.
Regards micov
https://www.sau.com.au/forums/topic/152003-improving-the-skyline-r33-gtr-vspec/
hey mate ive just doing some work on my 32gtr now
gt2860r-5(2530)
pfc+hc
cam gears in,ex
cooler
dumps/fronts
600cc tomei squirters
044 pump
+more just cant think.
will easy get 300kw with this setup i hope.aim is 320awkw so time will tell.
there is also already a thread on these to turbos and well,by far are the 2860r-5 a better turbo for good power and response. check it out.
ps any pics of this mint gtr
Its good that you dont do burnouts, they are pretty hard to do in a 33gtr :)
Since you havent mentioned the clutch it could be assumed its stock? If so you could try your luck but definitly budget for an upgrade. It may already be an upgrade item your not aware of.
Sounds like you have a pretty good plan. I doubt you could go wrong with any of your choices of turbos, you just have to choose. People will tell you pro's and cons about each of them, but i have also heard that the trust's are awesome and are capable of more top end should you ever get bored.
As in gun32's post, dont forget the fuel system.
Edited by SLY33
spot on..clutch is a must i forgot that 1..both good turbos do the research and decide for ya self...cheers
Nah I meant fast take offs 6000rpm launches you are right about burn outs damn near impossible
gt2860r-5(2530)
pfc+hc
cam gears in,ex
cooler
dumps/fronts
044 pump
hows this not sure how to post a pic abit new to forums
Edited by ike
Any recommendations on clutches is there any single plate jobs that can handle that power and same action as stock . Don't want to load up engine thrust bearing dont want to pay the earth either
cheers mate
hc= hand controller.
there is a bloke by the name jim berry i think who ive heard builds awsome clutches for like 1200 bucks and they can handle shit loads...
i got a os giken twin plate
Thats one nice looking V-Spec :O
400R rear looks great! be sure to post your decisions and results.
Looks as though you have some fine cars especially the rb28. keep us all posted on it.
Would'nt mind buying a clapped out r33 gtr for a project .
just bought PFC,HC and optional boost controller from Nengun $1200 delivered , hope to fit in 2 weeks
so I,ll let you know how it goes. then I can gradually build it up bit by bit sensibly and end up with a reliable beast. That way my lovely wife wont notice heh heh. :)
  • 6 months later...
Finally fitted PFC with boost controller and a twin plate nismo coppermix clutch. Old one shagged.
Getting around 220kw at rears I think (tuned with 4wd dyna pack)
Now collecting new parts for rebuild.
Have a new N1 block (from japan)
and a good suspension kit.
Waiting for Tomei 2.8 stroker kit
Lots of other Tomei gear
Oilcooler/sump setup
Trust T517z 8.0cm
Bigger brembos 6P 355 F 4P 340R
hks evc5
need a roll cage
Should be ferken responsive hoping for a good reliable 350kw at the wheels
Edited by ike
  • 4 weeks later...
Three weeks to go and it will all be finished .
Gearbox also being overhauled with full OS guts.
ATI harmonic balancer.
trust r-spl IC
Only thing left is the diffs anyone recommend good LSDs 1.5 way or 2 way I am a bit dim on this subject could someone please enlighten me
Also want a well fitted roll cage anyone know of any.
Beerbaron and Blitz you guys seem very knowledgeable.
Spent a shitload of coin on this car but it is worth it .
My aim is to compete in the dutton rally and other similar events not drags.( they are a drag)
Will post results
Hey also off the subject whats the go with the 10% warning below my avatar Admin guys.
Heh heh lots of views but no comments
As I said before this site is starting to get a bit too clicky for me
There are some very knowledgeable people on this site
But too many dyno pullers (fantasy land) who pour over dyno sheets and rave about boost pressures when its all about flow first .
Then you get awkw rwkw jockeys BHP is the one on a real dyno or hub dynos (dynapack) Been a hands on mechanical engineer all my life and drive train losses are minimal. ie less than 15%
I am having my car built for response,reliability and endurance for weekend racing but should easily do a low 11 should I want too.
Joined a Japanese site and are these people friendly .My language skills are improving.
Must be an underarm Australian thing (Go K1W1) .
Well a lot of info is already on the forums.
When people comment on the same topic 6+ times, they tend not to do so after a while.
Especially when a topic like GTR/Turbos is so common.
Also you havent really asked any direct questions in the last few posts, more comments... and the questions you do ask, are better suited to other sections where the experts in those areas are looking more often :P
Mabye you should read my post properly Nismoid. I was asking about the in and outs of the different types of differentials as I am not to au fei with them and want more knowledge on the best types for track racing.
Have not asked about turbos for a while as The T517z 8cm are the ones that are going on my engine ( as we speak) Although it would be nice to hear from anyone with these turbos on a tomei stroker.
Just seems to me that you have to sling some shite to get a response on this site.
But I will definitely check out the Drive train section Nismoid
TY
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
