I'm finally about to order the gear for a power upgrade on my R32 GTR.
The list so far includes:
HKS GTSS
HKS dumps
Apexi PFC + HC
Sard 700cc injectors
Bosch Z32 AFMs
Tomei AFM Adapters
Tomei Sump Baffle Plate
NISMO Fuel Pump
N1 Oil Pump
I've already upgraded the clutch, oil cooler, oil relocation kit, oil catch can, turbo back exhaust with a high flow cat, 125mm FMIC, front pipes, HKS airpods, suspension, brakes, flywheel and gearbox.
I'm after 300-320 kW that spools early, has low-end power and is responsive. Car is driven mainly in the Adelaide hills with an aim to do track days. I will probably take it to the drags once (more if I enjoy it) but that's not my priority.
My question is do I need pon camshafts and if so which one?
From the nengun site it states: http://www.nengun.com/tomei/pon-camshafts-pulley-set
Type A
In order to get stable idle and raise low-mid RPM torque, we set the duration of EX camshaft shorter.
Best suit used with stock turbine or N1 turbine.
Duration IN 260 EX 252 Lift 9.15
Type B
By giving longer duration timing than type a, it eables to raise both response and peak power at the same time, even with mid-large sized turbine.
Duration IN 260 EX 260 Lift 9.15
Looking at the other SAU guys who've posted their dyno results here http://www.skylinesaustralia.com/forums/in...showtopic=93880
most with HKS GTSS turbos & poncams have the IN & EX 260 (Type B). But reading the info from Nengun and believing that the GTSS are similar to N1 turbos wouldn't the Type A be more suitable?
Cheers.
https://www.sau.com.au/forums/topic/152224-question-on-pon-cams/
Most people aim for the mid to high end of rpm range cos they see the peak outputs up there. I'm interested to know as well as I was planning on around step 1 262 cams. I'd get some opinions on what people have got and what they drive like. Should be a few....
Good luck with your choice.
I've been advised to use stock cams with my GT-SS/RB26 setup.
That's interesting. Why?
I kind of expected to get answers or opinions on this question from R31Nismoid, Beer Baron, wrxhoon, pnblight & 700HP-GTR33.
I would really appreciate input from HKS26T, Snowman, williamsF1, GTR032, jonn, yug r34, pure_methamphetamachine, The Alchemist, SLVR32GTR & RH9 who either have the turbos, poncams, or both to know what info they had that effected their decision to buy. What are your experiences/recommendations?
Cheers
Cheers
Im currently using all the same parts you have listed including GT-SS's with Type B Poncams and putting out ~315awkw on CRD's dyno.
I have seen other cars with the same turbo setup setup but stock RB26 cams only manage 280awkw on the same dyno.
im doing similar mods to you but im using gt2860r-5 and will not be using cams.aiming for 320kw so maybe save money and see how the setup goes without them..
my2c
I've been reading about your power upgrade with interest. I may contradict myself now as I saw the HKS 2530s for sale and $2000 seems a good price for these turbos with HKS dumps. Mushi Mushi states that they come on at full boost at 3200-3500 rpm but from what I've read this is about 1000rpm sooner than I could expect... right?
With the money I'd save over new turbos & dumps I could get the Type B pon camshafts.
Edited by writeoff
Why? Because my tuner has played around with it all.
And i trust the best result will be attained. :D
I will have cam gears on there though to move things around a bit.
I also wanna push the stock gear as far as it can go and then compare with Nick(blitz), Andrew(Snowman) and others who have differing parts to what mine will have and see what strengths and weaknesses all setups have.
I dont mind giving things a go even if they dont workout right.
If, after comparing with the others that i feel there is a gain to be had, then for sure i'll start fishing around and looking at cams and that sort of thing, but i wanna give the stocker gear/tuners advice a crack first as i have not been failed by the advice ive been given :)
In saying that, Ferni has GT-SS/Stock cams and has made 300rwkw thus far and i have a couple extra parts than him for mine.
Hope that gives you my insight into it.
What hp shot of NOS is mushi mushi running?? or is he running a stroker?? stock turbos get full boost above 3000rpm, can't see how 2530's can get full boost by 3200rpm...
maybe mushi can post up a dyno graph to prove it...
Let's just say that 2530's are bigger than the 2560R-5, and they get full boost above 4000rpm....
Am I the only one thinking this is a croc???
my car has a different turbo setup but thought i would gilve ,my 2 cents,
found with stock cams my car was making 321awkw and then with poncams 260 9.15's went up to 344awkw, boost was came on sooner with more midrange and topend torque/power, was quite happy with the results,
will be good to see the setups you guys have and see the differences in power with/without cams,
I will be having my car tuned soon 2530s with stock cam soon but i can tell you they dont come on to after 4000rpm on my current tune.
current tune has stock dump/fronts which is being rplaced now with full HKS turbo back exhurst system.
edited
I think we should only compare GT-SS with GT-SS, the 2530's definately get cam treatment of some kind... where (what we are debating here) is whether the GT-SS need them or not, which is interesting thus far :D
Thanks for your input Blitz. This is the kind of information I was after.
I note that williamsF1, The Alchemist & HKS26T also have HKS GTSS Turbos with the Type B poncams. Has anyone ever seen or heard of using the Type A poncams?
PS - going to stick with the original plan. Just got excited over the thought of cheap(er) turbos.
Edited by writeoff
What hp shot of NOS is mushi mushi running?? or is he running a strocker?? stock turbos get full boost above 3000rpm, can't see how 2530's can get full boost by 3200rpm...
I worked out where it was said.
For Sale section, he is trying to sell off a set of 2530's... so of course he is going to make them sound as good as he can... even if its highly unrealistic
Cams will make a difference mid to high RPM, you can use either type A or B, not much difference in them but i would go for type B.
I don't have cams in my car because I didn't want to open my engine and its easier to pass emisions test if need be.
You can't really compare different cars on different dynos because you will get different power figures. Even the same car on the same dyno the same day you can have different power figure .
The bits you listed above will give you good power through the rev range and a very good response if you have a healthy stock engine but don't expect huge power up high.
I have GTSS turbos in mine with stock AFM's and she has stock like response with much more power mid to high . I have run a 11.8 second 1/4 mile with a 118 mph trap speed but its a very low ( genuine ) km series II 34.
How do you intend to install the oil pump? Sump baffles? Engine out?
Thanks for your input wrxhoon. The short answer is that I'm going to pay someone else to do it. I have very little mechanical knowledge and have limited movement atm due to a serious car crash on Jan 3rd. I haven't decided which workshop I'm going to get to do the work yet. I want to drive to the various workshops and talk to them first but I'm carless atm. The Bentley was written off, the grey GTR has a blown turbo (hense the upgrade), the white GTR is sold although the buyer is stuffing me around with payment & the Peugeot is in for repairs. 4 bloody cars and I'm catching taxis. :(
I take your point about not being able to comparing dyno figures - they are a only a guide - I am interested in the thoughts and opinions of people with the GTSS turbos with or without the poncams. However dyno figures can give an indication of when the turbos come on boost which is what I'm interested in.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
