  • Replies 169
haha is the second last one from when some dude was telling the cops theyre just picking on him cos he's lebbo ?? :wacko:
obviously didnt see his mate fry his tyres into the cop car
haha love the guy on the myspace vid...as the car passes him he screams... YEAAAHH!!!! then next thing AWWWWWWWWWW NOOOO!!!! NOOOOO!!! as the cop car pulls up :wacko:
ok i now really wish i didnt go!!! when i parked up at Hillaries, after about 1 hour i came back to my car to see a couple of people leaning on the back of my car, so i thought id go and pretend to get something out my boot to make them move and politely say excuse me but f**k off lol, didn't really check anything as they moved on, (their mates car was parked next to mine) looked it it just before and there heaps of scratches on the left hand side of my boot and also on the tail light surround, not hell deep but noticeable, my uncle says polish may take care of it, looks like the guy was wearing a belt with emo studs in it and as he has rubbed up against my car it put scratches in!!!
thing is i cant 100 percent prove it was them or weather in fact they caused it but im just pissed off :D
oh to people that did burnouts and got caught, SUX TO BE YOU :D you got what you deserved :wacko:
thanks for stuffing it up for the rest of us :huh:
Ignition?
Of course they will come back. Andrew was thrilled with it, it was the biggest turnout he's seen.
Will there be many decent cars at the next one?
Doubtful, not many people are going to risk getting a sticker if they know this will happen...
It's not their scene. None of them will end up on the Ignition DVD because it's not their scene. Motorvation and Revheads are their scene, they should f**k off and let imports have their fun.
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
