hey guys,
was outside eating a pizza and decided to roll my VS-KFs over to the ceffy to have a look at what they'd look like on it. starting to get second thoughts about using them on an S14 :D
suits the colour really well i think.
car should be going really soon hopefully, new engine is built and alls thats left is to decide weather to keep the current Tsp kit or use my uras kit...im starting to lean towards the tsp kit as i havent seen another ceffy with this on yet in aust :)
https://www.sau.com.au/forums/topic/152294-some-inspiration-for-myself/
yeah dude, seriously man-up and stop listening to your girlfriend, you can't let her rule your life you gotta show her who's the boss..
put the damn wheels on hey, man up dude...
that's my advice
that's my advice
what the stock CA ones :P
vs-kfs are 18x10 and 18x11 -13, they where going to go on my next car (s14) and just get a random set of wheels for the ceffy, which will just be a pig slider. but we will see soon enough >_<
the mrs S13 convertible will be up for sale soon to fund the said project >_<
they dont fit as crazy as you'd think, on the S13 vert the 11s only sit outside the guards a couple of centimeteres (with a small overfender) so on say an S14 with large guards it should sit under. its the fronts im more worried about as the spokes just touch by about 1mm on the R32 type M brakes. i hope S14 is different
Some small slip on spacers will help over come any issues with brake clearance.. I'm running 5mm + 3mm spacers each side at the front with my 18x10 +8 Stiches.
Rears are 11 -1 with what I think are R33 hubs. Just to give you an idea on what guard mods you will need
Edited by Drift_Limo
not at home atm
but rears on my cef were 18x11 +0 on my efors... -2.5 deg camber and 225/40/18 stretched over the 11's... same overfender as drift limo's sat in about 15mm...
drift limo looks like running less camber thus fills out those guards
btw if you want a set i have some here... 400 bones n theyre yours
Is this car driving around yet?
A31cefiro - that's fat.. keep it.
drift_limo - that's also fat. Are they moulded flares or just really ambitious guard rolling?
Bolt on flares smoothed over..
No its still in deep hibernation... Sold the replacement 25DET a couple of weeks ago due to being poor arse hobo :laugh: It does run on, 4 cyls with a Wolf base tune. Not good for the wastegate though :P
omg drift limo, so sexy, wish i had that look.
Cheers for the kind words and huddy... Wolfwood yours has so much potential.. I like AVS's but could look soo f**king horn with mega lowering and some dish under those guards.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
