With regards to imports and the compliance plate etc I don't know.
If its the same model/size motor all is required is to notify motor reg of the new engine number.
I did this some years ago but not with an import; pop through your local motor reg and fill out a form. Unsure if they issue a new set of compliance plates and what not or if it really matters. Providing its listed on the rego slip it shouldn't.
It may depend upon what you are swapping.
My experience was with older cars where many of the current rules didnt apply, but the basics were that the engine couldnt be any larger than the largest engine released in that model. (In my case it meant no chryslers with motors bigger than 360 ci)
They were also very concerned with brakes and wanted upgrades beyond those that the manufacturer released on the models.
Are you looking at a modern vehicle or a classic?
I doubt it would be feasable to put a V8 into a skyline but they think its OK to put 440 ci into a mini or worse a vintage car with wooden spoked wheels. (but ADR's dont apply to early cars)
Edited by 4door_Sleeper
Grepin.
Are you considering dropping a stocker in to the R33 and selling off the other motor as a package of sorts?
Yeah certainly am. I have put the car up for sale here in the forums and dont really expect any buyers at $27000 although there is more than $35000 worth of bits alone. So next step would be to sell the motor as a whole package and or slowly sell the bits off. The main issue is that it has the head with GTR cams etc or the bits would come off and stock bits on. Would be a nice head on a 3.0L. Motor out and motor in would be easiest.
LOL i just replaced my dead RB20det.
I think u can get a good cond RB25det for around $3 - 3500 if u know where to look. And yes i think they need to see the car. But i have the engine number written down on a piece of papaer from when my new engine was out.
Hope this helps. i will tell u later tonigt what needs to be done.
Cheers,
Brenton
i swapped an engine in my LH Torana from a 173 6Cyc to a hot 253 V8 and i was told as long as the car came out with that engine it was fine to swap it. the torana came out with a 4Cyc, 173 or 202 6 Cyc, 253 or 308 V8, so i could have put any of those engines in my car legally.
dunno if that helps
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
