  • Replies 44
Steve You Smell. LOL.
I still have to come back to your place and get the compliance papers from your work.
Im a slack/ lazy boy.
Will see u out at the BSM cruise on the 4th. Looking forward to seeing u there mate.
Brenton.
P.S. there have been some slight changes to my car since u last saw it hehehehe
hey nisswreck,
im after a series 2 grill 96 model and a drivers side power window surround
not the whole assembly with switches just the long plastic bit,
pm me with some prices and availability
thanks
I'm pretty sure Andrew(Nightcrawler) on here in SA has one, prob with piping and all! You should hit him up a PM!
Actually I'm pretty sure that he doesn't have it any more. If memory serves me correctly Prof_dls bought his off of him & put in on the 33 he had before it was written off. Just happend to come up in coversation when I saw him at his place after the accident.
Could I also please be PM'd with a quote for a R33 S2 interior rear view mirror & for a passenger door attaching loop (I don't know it's proper name, the part where the door latches to the body) & a drivers side door trim. All need to be in good condition to be worth while for me.
Cheers
Edited by JazzaR33
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
