  • Replies 87
Posted Images
Wow this is great.
If you don't recieve a PM reply back in here. Myself, Nathan or Mark & Julie will PM all who have asked for one.
Please try and get as many friends to come. If u all chip in say $2 each or how ever much you want it all goes to a good cause.
Im not sure on $$$ raised last year but from the looks of it there will be alot more cars/ people on this cruise.
Im looking forward to it very much.
Its going to be a day to remember i think with alot of SA's best cars out and driving on the roads.
Police will be notified and will hopefully not hasle us that much.
LOL I remember GT George getting pulled over in his S15 last yr and telling the cop what the cruise was all about.
yeh i cant really remember what last years figures were, but every penny counts......and its for a very good cause
if you manage to get friends to tag along, remember to tell them, NOOOO HOONING, please dont be stupid on the cruise
Damn good cruise, will be there for sure!
Any of the down south boys keen to meet up before hand and cruise to the start point together?
check. However I would like to get to this one on time, or early even :( I have a bad track record
MEETING PLACE
Seen as SAPOL are aware of the cruise, I cant see any point in not revealing to meet location....if they want to harrass us when we are gathering for this purpose, then it shows their true colours. I must admit they have always been good to us on this cruise, in the past.
OK we will be meeting at 1pm at a very sentimental location & the map will reveal that....(this is where the cruise on the day of Ben's funeral left from) Jack High Lane at Ridgehaven, remember to follow this road up (from the Golden Grove Rd swimming pool & funeral home entrance) to its very end...there is a large carpark between the footy oval & the bowling club....and an overflow carpark besides the bowling club.
Now we are asking for a Gold coin donation (for the route map) which will be given to the White Wreath Association...many will remember their display in Victoria Sq, last yr
JACK HIGH LANE.....remember to follow it up till it ends
Hope to see you there......
"the dr1ft_pig13 OLDS"
OLD Jules & Mark
Edited by mark03
you'll wanna meet up atleast an hour before the cruise meeting, maybe more just so u can wait for everyone and then cruise down together
pretty decent distance between castle plaza and golden grove side of town
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
