  • Replies 117
mate do u have the centre console lid without the cup holders?
yep sure do i dont remeber seeing cup holders though best to call wen im in garage wich will b saterday on 0410 388 994 cheers
  • 4 weeks later...
  • 1 month later...
hey mate, still have the 550cc injectors listed in the 1st post?
willing to post em to wa?
anything wrong with em?
im keen!
hi mate i still have the injectors i recently had them flow testd and ther all good thay are 500cc and can b pushed to 550cc thats were my tunner got hes numbers i can send no probs anywere in australia so any other qestions call 0410 388 994
cheers
Does the AC Compressor work ?
Do you have the Centre console plastic surround ?
and either the right or left quater glass surrounds ?
not sure if this has been asked, but can i get stats and price on the wheels?
price on wheels are 2200 as for the specs i know ther 18 inch rear tyres are 255 and the front are 235 i can get my details for you asap i dont know the specs of hand best to buz me on weekend while im at home and i can have a look buz me on 0410 388 994
cheers
compressor sold i need 1 my self ,center console gone.i still have quater glass surounds ok condition not the best any other qestions buz me on 0410 388 994
  • 2 months later...
  • 2 months later...
Hey, did you still have the AC condensor and fan?
Cheers
hi mate sorry for the late reply ive been busy as i do have the ac condensor perfect conditon 0410 388 994
cheers
Hi Mate, injectors still for sale? Is there anything special about them eg different impedance to standard GTR's?
Have they been flow tested? km's? I'll ring tomorrow, bit late atm.
hey mate the injectors are sold cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
