This car just isn't practical for me anymore. It barely gets driven as my work is less than 1 km away from home, and I have commitments which require me to have a bigger car. So as much as I love this car i have to make room for something else.
Item: 1993 R32 Gts-t
Reason for selling car: New car
Price: $14,000 firm
Kms: 123,000
Contact - PM me or 0434361959 (after 4pm)
Condition: The car is in immaculate condition. It is always undercover and paint has been meticulously looked after. You won't find a better condition r32. The car has been serviced every 5000kms with all work done by Proconcept.
Engine Mods:
R34 GTT turbo
Trust VSPL FMIC
Apexi AVC-R Boost Controller
GFB Mach 1 blow off valve
Full exhaust
Walbro fuel pump - 500hp
Ecu remap to suit the turbo and pump
Aftermarket POD filter
Autometer Boost Gauge
Car has made 189kw on 13.5psi with dyno papers
Wheels:
18" Wheels
DBA brake upgrade on the front w/slotted rotors
Project Mu brake pads
Suspension:
Cusco front and rear strut braces
Full whiteline suspension kit - sway bars, bushes, shocks and springs
Bilstein shocks
Interior:
3 point immobiliser
Cd player
Rockford Fosgate amp
Splits/6x9's
Exterior
Full Vertex bodykit
Have just had it serviced with new oil, oil filter, fuel filter, new Pod, new coolant and new spark plugs. Runs superbly
Note: There is some slight damage to the paint on the boot from removing the wing. Haven't had time to get it painted. Have been quoted $300 to fill the holes and spray. Can get this organised for the buyer
Only Genuine enquiries please
Edited by patto1234
https://www.sau.com.au/forums/topic/152940-1993-r32-gts-t-modified-immaculate/
any interior/engine bay shots?
The 6x9s, are they in the rear? If so is the parcel shelf cut to fit them?
Also has it had a major service done at any point? ie. Timing belts etc
I can get some interior shots and stuff if you would like.
Not sure about the 6x9's, they were there when I got the car so I can't say for sure. And yeah its had the major service done. And as mentioned I just had a number of other things serviced the other day so its running very nicely
Being interstate, the more photos the better :sick: as its a bit hard to just pop over for a look.
you could email em to [email protected] if you want.
Cheers.
Sale temporarily postponed due to unfortunate family situation. Will "reopen" the thread when I am in a better position to be selling the car but right now I have my priorities. Apologies to all those who were interested.
Hope everything works out Patto... when your ready let me know, no matter how long it takes...
Thanks mate I appreciate that. I will let you know the second it's back on the market.
  • 1 month later...
Bump
hey mate is the car still available as i tried looking for it on carsales but couldn't find it, if it is i am more than interested in the car and would you be able to send me some interior and engine bay shots? ([email protected])
thanks Nathan
  • 3 weeks later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
