Spoted "EVL-033" crossing the bowen bridge about an hour or so ago.
Was ussing it as a speedo as I forgot to hock up my speedo when putting my new engine in.
Was basking in the all mighty raw of my insane RB30DET
lol hey mate yeah i spotted u to was waiting for u to come flying past. wouldn be using me as a speedo lol it aint to often i driving legally. whats been done to ya car mate? what she putting out at wheels? oh and yeah spotted you alot to trent whats ur car running?
haha EVL033, i see you basically everyday lol my sis lives down the road from ya lol not sure how many kw my car is running, im going to put it up on the dyno very soon, but yeh, it doesnt go too bad, how about your's?
Yeah I was thinking about it but knowing my luck there would be a cop around the next corner.
I got booked the other day doing 94km/h in a 80km/h zone... apparently tachos arn't that good to guess your speedo off. :P
I will have to hock it up one day :S but it soo far out any way being that I have 4.11:1 diff gears and 18" rims.
I havn't dynoed it yet as I am waiting to finish the engine off, Microtech LTX12s is yet to go in and a bunch of other things, I am aiming for a solid 300RWKW tune for street use and a slightly higher reving 350RWKW or so for drags. I should make that easily, engines good for 400RWKW with a big enough turbo.
spotted a black 32 gts4 with big dish on the front and burn out rims on the back... now it wasnt the car that caught my attention..... was the beautiful blonde number driving it lol... sum one on heres missus maybe???
Spotto'd a few 33's today and over the last few weeks. Mine, anotha white S2 gtst and a yellow GTR at uni as well as a black gtst going over the bridge at peak hour today. Usually see a white GTR, a white S1.5 and 2 different silver S2 gtst's around sandy bay also :thumbsup: I know theres alot more that i have seen but cant rememba rite now haha. Good 2 see lots of ppl gettin into the import scene, especially R33's :(
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
