Ha Ha! yeah thats about!
Its good for a laugh!
and then the next funniest thing is when a guy cant handle the fact that a girl just beat him in his white ute! and then has to try and make himself feel better by going around saying he flogged my car! little did he know... that he was saying all this in front of the passenger of my car! opps on his behalf!
The R32 this weekend getting some love (and seeing daylight) for the first time in a couple of years. Finally got around to finishing off the body work. Looks a bit rough in several different colours thus far, but its ready for paint...
HKS Hyper-Ds to go in and then it will sit a fair bit lower. Not sure how it will get out my driveway tho :D
haha! well thats definitly the case, drove through town on fri night before going out of town for a while :cool:
... the amount of people mouthing off was unbelievable, nothing original though! 3 seperate groups, all said same thing! no wonder i usually drive round with the music turned up! LOL
Hobart's the mouthing off capital of Oz.
the only way to command respect is to drive some form of holden. A safe bet is a hq. it must have a v8. with pushrods, and a big dirty holley and most definatley roller rockers and without doubt, straight cut timing gears(this is also known as Fully worked or HOT mota). "stractors and hot dog and probably a lukey. tires = Fat. wheels, centrelines are a winner.you must wear a flanno jacket, tight black jeans, a mullet is the prefered choice of cut and the only beats to be played are ACDC. and there's no bloody latte's or souvlaki's about it. meat pies and crap beer is the only way to be rolllin. and ya favourite waterin hole has to be 'the Don'
hobart, "hate this place!" haha lol.
(nothing against muscle cars, next cars gonna be a mopar monster, but hobarts still a shit bogan town)
;):D:):):)
LMAO! Definitly Couldn't have put it better myself, Its not just Hobart, Launnie has this Small town Syndrom thing Going on too, Its just Hobart has more of everything from shops to bogans!
Lol i think its like that every where u go :\
Tas wise. The other week i was in devonport, there was this bloke in his r31 all the doors open the bonnett open and the boot open crankin the music i mean come on....... Then theres the idiots that fly past you doing fair bit over 60 in there boganised commadores outside a school.... people like ruin it for everyone else.
i like :laugh:
? lol
I was heading down to hunter street to meet up with the guys going for the "fireworks" cruise. after a long day and a few frothies I totally forgot how un-import friendly hunter St is and plowed into a gutter. lucky my front bar is Bull shit tuff (thanks FibreSport!) and ended up with no real damge. few scratches, no extra cracks. sounded nasty.
shits happens. was a good laugh. as much as I try to keep it looking neat, its still "go before show"
lolz.. which kerb did you hit?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
