Its a GTS-X, came in from japan with the sticker and spoiler already on it. Has a few fancy things in it. Like a self adjusting rear view mirror which i need to fix, also the electronic in cab adjustable suspension still works, but only the front as it has aus spec struts in the rear.
The plan is to stick my s13 coilovers in the rear soonish to bring it back level, will eventually go s13 coils in the front, along with r33 gts-t brakes all round and a nice set of fat wheels. And also my RB30ET will be going in along with a high mount turbo. Not sure if i'll stick with the GT3082 or if i'll go with a different turbo. Also plan to put a R31 house front bumper on it, and maybe a carbon vented bonnet. Not sure. I should probably call this one money pit 2.0.
Thanks for the positive feedback fulla's.
oh and :D
nice one ditch the wing and sticker :worship:
i had to take the clagged out adjustable suspension out of my coupe to it had two great settings spongey and boat mode gave it some coilover love and it loves it now. mine doesnt have the flash mirror thingy though would love to check that out
Spotto a mint looking bayside blue r34 in Launnie yesterday :O
if its the one im thinking of i met the guy tonight, and yeah its prime!!!
he said hes had it since 05, but just had it as a weekender
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
