Been a long time since I've played with those but I think C33 twin cam is the same as A31, any reason you're not using the engine loom you had before? Engine side is pretty much the same except the cir clip type plugs on A31/C33 so could swap plugs or electrics to suit.
1:13.559 My 'optimal' was 1:13.3-ish so I feel like I didn't leave much out there.
I had 295s on mine when I had a 34 and they didn't rub and that was with Nismo coilovers
Had a change of plan on my HICAS set up so have for sale a Midori Seibi canceller kit. Its not been used but has been test fitted Based in the UK but shipping to Australia is no problem £230 delivered to Australia (I think its about 450AUD :))
Hi ok thanks. So theres 2ball joint front 2 ball joint at the rear? Hi gets boy, soz and yes 2 ball joint for the front lower arm key adn right and rear is als 2 ball joint for left and right. 1 for each corner
