Spotted a white 33 with SAU TAS sticker on the passenger side... was on the brooker, tried to get your attention but there was a truck in the way
Series 1 with a series 2 wing? I have been out that way a decent amount over the last few days heading in to see the wife in hospital. What were you driving?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
