First Car To Be Confiscated Permanently Under Hoon Laws
Great publicity for the Skyline community! Police have applied to seize the car permanently, which would make the first car to be permanently seized a Skyline if it goes through.
Sucks that Skyklines make the top 5 list:
The five most impounded cars are:
Holden Commodore
Ford Falcon
Nissan Skyline
Holden utes
Ford utes.
The most common make of impounded cars are:
Holden (50 per cent)
Ford (16 per cent)
Nissan (nine per cent)
Toyota (five per cent)
Honda (two per cent).
Yep, i'm way toooo scared too take my car through dandenong. Though i'm yet to be pulled over... Last weekend i was on heatherton road and a cop came opposite me with his spotlight on, looking in my rearview he did a u turn (as expected) and launched and was right up my behind. I merged into the left lane and continued driving normally. I had my L plates up and my brother was with me, i thought i was a goner for sure due too my FMIC and my kind of loudish exhaust <_<.
Stopped on a hill bit and he stopped probley about 30cm behind me?
Now that i think about it i should've stalled or somthing and rolled back into him =(
Lots of cops give looks but they still havn't pulled me over, though people are saying their just taking numberplates n things and handing out a load of epa notices? *shrug*
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
