hey all, just picked up a new turbo today. was expecting to get a standard S2 RB25 turbo
upon closer inspection it seems that its got a GCG ID plate stamped onto it, which leads me to believe that its been rebuilt/high flowed.
Having never seen a standard turbo in person, i have nothing to compare to.
Can anyone confirm this?
Well lucky me then :):laugh:
this is really going to put a hole in my wallet now since im going to have to get all the supporting mods to really make use of it
i was onli going for a little bit more power which is why i was looking for a standard turbo
the guy i bought it off was using the engine to do a conversion and already had a turbo for it, he thought this one was standard, well that was until we pulled the manifold off and saw the ID plate
thanks for the input :(
It's definately a highflow but it has a 7 blade front wheel which I haven't seen in a GCG one before. I'm with R31nismoid, give GCG a call.
I ran an old GCG stage 2 highflow on my rb20, 14psi by about 4300, made 175rwkw at 12psi with a massive torque hole at the bottom end :happy:
That exhaust wheel certainly looks a hell of a lot larger than stock and I think that compressor wheel/inlet looks bigger than the standard 25 turbo I've got sitting at home.
alot of mixed opinions here lol
it has a gcg plate as ive already pointed out, i looked at their website n it does look the same.
i did call them aswell but im waiting on a call back
i might just go in n see them myself
It is a GCG trust me.. they even sprayed the actuator black as well.. exactly the same.
GCG have definately high flowed the exhaust side of the turbo - got the big arsed wheel in there for a nice n steady 19psi of boosting! Not sure about the front tho, cant tell by the photo. For all I know its a standard front wheel and a highflow to the rear?
Either or, a very tidy pickup for $450 mate. Set to 1bar there is no doubt that you'll be a happy chappy
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
