  • Replies 121
hey mate i am interested in the apexi fmic kit. how much do you want for it? can pick up as well. i might even get the injectors as well but will see how the founds go this week, let us know
cheers
cheers
pm sent
Ok guys sold the Apexi Cooler.
I still have:
GT3071R Turbo Kit. $2500
SARD 550cc injector Kit (NEW) $700
OR BOTH FOR $3000
BOSCH 040 $200
TEIN COILOVERS $800 0N0
APEXI TIMER $50
CHEERS,
BILL
I still have:
OR BOTH FOR $3000
BOSCH 040 $190
TEIN COILOVERS $700 0N0
APEXI TIMER $50
CHEERS,
BILL
ATTENTION ALL PRICES HAVE BEEN SLASHED!!!!
Here are some parts I am selling:
1. GARRETT GT3071R 500HP TURBO KIT 1.5months old has 10months warranty from GARRETT
exhaust a/r 0.71, compressor cover a/r 0.5.....made 237kw on stock boost on the standard fuel system,
(comes with 4inch intake from comp cover to AFM and mates with standard BOV position, teflon braided oil and water lines and custom turbo elbow to cooler piping, adjustable w/g actuator,4inch silicon for comp cover and 2inch silcon for turbo elbow, adapter plate...with lots of reciepts) cost me nearly $4000
$2500*
7. TEIN adjustable coilovers suspension set (adjustable height/rebound/compression) great for circuit or drift - $800
8. Bosch 040 500hp intank with new fuel lines (ready for direct replacement) 1month old - $200
9. R33 S2 10/97' OEM Fuel Pump - $90
10. 6 SARD 550cc injectors Brand New - $790
11. JVC CD Stacker 12 disc - $100
12. APEX turbo timer - $50
13. Mickey Thompson Street Radials 2 brand new (275/40/R17) - $490
FITTING IS AVAILBALE IN MELBOURNE FOR A NEGOTIABLE PRICE
AS A PACKAGE - turbo & injectors- $3000
No stupid offers please.
HEY ANY PICS OF THE TURBO TIMER? pm ME WID THEM PLZ
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
