  • Replies 166
Posted Images
Guys I may need to pull out of this one, unless i fix my ldling/revs.
3 days ago my idle decided to play up. Havent got to the bottom of the issue yet - I.e It idles at 1.8k revs now and feels less responsive when i use the throttle. I haven't changed anything recently.
I have cleaned afm, and aac valve but still no good. Any ideas on what you guys would try/check next?
https://www.sau.com.au/forums/topic/153441-closed/page/7/#findComment-2888848
looking forward to this. it will just be me at this stage, Tash has to work - the hours suck when you work in hospitality industry. will be good to meet some more SAU people and do a cruise i didn't help organise for a change. plus I can show off my new wheels that arrived last friday.
Ian, whats the go with the pizza - do we chip in a few bucks for a couple of pieces, or order a whole pizza?
https://www.sau.com.au/forums/topic/153441-closed/page/7/#findComment-2891844
Umm with the pizza, you can go halves with someone if you want? but at this stage im just taking whole orders for pizza.
I have an unlimited large pizza's for 6.95 voucher here, so thats the asking price. Plus extras. GTR Pizza delievery car. Id say it was a first, but theres a good chance its been done before....
Okay, ill update the list. A few departures, a few additions. We should have about 25 cars, so its going to be a bigish event.
https://www.sau.com.au/forums/topic/153441-closed/page/7/#findComment-2892411
its been done before... i know a manager of a dominoes who has a Silver '32 GTR :no:
https://www.sau.com.au/forums/topic/153441-closed/page/7/#findComment-2892444
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
